How do I drill Gelcoat without cracks >
Old 08-27-2021 | 08:18 AM
https://www.northerntool.com/shop/to...E&gclsrc=aw.ds
I use these tap drills. They drill, tap and countersink. Works great
snapmorgan is offline
Old 08-27-2021 | 08:25 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If you can get to the backside, I strongly suggest through-bolts for them.
Sydwayz is offline
Old 08-27-2021 | 08:26 AM
I like
masking tape
Philips screw driver
Can't thru bolt it, no access
counter sink, saw online larger diameter drill bit turning backwards.
thanks for all the ideas
PA.WOODCHUCK is offline
Old 08-27-2021 | 08:46 AM
Rookie's Avatar
Masking tape, countersink or chamfer with grinder.
Also measure 4 times!
Rookie is offline
Old 08-27-2021 | 11:56 AM
Holy Holes Captain.
SabrToothSqrl is offline
Old 08-27-2021 | 04:03 PM
Originally Posted by PA.WOODCHUCK
I like
masking tape
PA.WOODCHUCK,
Take the drill bit you want to use to a local machine shop and ask if they can sharpen it "for brass". They'll know what to do. If you have a bench grinder and are at least somewhat handy with it, try it yourself. See
Thanks. Brad.
Model Machine and Precision LLC
(937)545-8991
Brad Christy is offline
Old 08-30-2021 | 12:17 PM
Going to install 2 strap brackets for Bimini with #10 screws. Best I can figure final drill size is 5/32. What technique for drilling without cracks.
thanks
I would say your bit is a hair too small, and thus will encourage cracking or chipping. I recommend an 11/64–it will be plenty snug, with no danger of twisting off the head. I simply cover the area with some blue painters tape, and don’t put too much pressure on the drill, because you don’t want it to grab. I’ve installed tons of #10 screws that way with no cracking, but also no other special procedures (although I’m sure they may be effective). If you’re going to thru-bolt a #10, use a 3/16 bit. As others have pointed out, thru-bolting is always better if you can reach the backside without too much trouble.
Labloverdc is offline
