How do I drill Gelcoat without cracks
Going to install 2 strap brackets for Bimini with #10 screws. Best I can figure final drill size is 5/32. What technique for drilling without cracks.
thanks |
Originally Posted by PA.WOODCHUCK
(Post 4803112)
thanks |
Originally Posted by lavey jr
(Post 4803114)
Easiest methods I’ve found are don’t use an extremely sharp bit, go in reverse to burn through the first layers, lightly counter sink the hole before you run the screw in. If you don’t have a counter sink or are lazy to change your bit you can also use your phillips screw tip as a small counter sink haha
(Post 4803114)
And use a very light touch ! |
Do not run the screw into the glass without an appropriate counter sink. Best done with a stone so as to not create any rough / sharp edges. Just want a smooth bevel, and do not over tighten the screw and pull the gell from the glass substrate.
(Post 4803114)
i always put down masking tape on the fiberglass before drilling, reduces cracks/chunks.
remove after drilled. |
Originally Posted by SabrToothSqrl
(Post 4803149)
Why dont you thru bolt it?
Masking tape and then counter sink
https://www.northerntool.com/shop/to...E&gclsrc=aw.ds
I use these tap drills. They drill, tap and countersink. Works great |
If you can get to the backside, I strongly suggest through-bolts for them.
I like
masking tape Philips screw driver Can't thru bolt it, no access counter sink, saw online larger diameter drill bit turning backwards. thanks for all the ideas |
Masking tape, countersink or chamfer with grinder.
Also measure 4 times! https://cimg5.ibsrv.net/gimg/www.off...06fbbf0358.jpg |
Holy Holes Captain.
(Post 4803194)
I like
masking tape Philips screw driver Can't thru bolt it, no access counter sink, saw online larger diameter drill bit turning backwards. thanks for all the ideas Take the drill bit you want to use to a local machine shop and ask if they can sharpen it "for brass". They'll know what to do. If you have a bench grinder and are at least somewhat handy with it, try it yourself. See Thanks. Brad. Model Machine and Precision LLC (937)545-8991 |
(Post 4803112)
thanks |
| All times are GMT -5. The time now is 04:29 PM. |
