Are the Merc 450s having any issues like prop shaft breakage >
Old 09-14-2022, 10:31 AM
  #31
Perhaps this new prop nut setup will help. I think I'll switch to this style from the single nut, it's cheap insurance and no-doubt makes a difference. Hard to go wrong with doubling up the nuts and applying more torque.
Grab the Torque Wrench
MercuryRacing
Team Racing
Options
4 weeks ago
The Importance of Keeping Prop Nuts Tight
Mercury Racing introduced a new Prop Double Nut Kit for all Mercury Racing outboards with a 1.25-inch diameter propeller shaft. The Double Nut Kit is designed to better secure the propeller to the prop shaft. Mercury Racing recommends checking the torque on the fasteners regularly.
The new kit includes a brass half hex nut and a brass locking nut. When installing the propeller, the hub and prop assembly should be placed on the prop shaft, followed by the supplied washer and then by the brass half hex nut, which should be torqued to 85 ft. lb. The brass locking nut is then installed behind the half hex nut, and should also be torqued to 85 ft. lb.
Note that the previous kit uses a single prop nut that could be torqued to 55 ft. lb. The new system accepts more torque, and the double nuts better maintain that torque. However, if the nuts loosen, in extreme instances the propeller can begin rocking on the shaft. This can cause damage to the propeller shaft splines, and even lead to the propeller shaft breaking.
For this reason, it’s good practice to break out the torque wrench after a high-velocity session. To re-torque the hub, the rear locking nut must be removed. Torque the hex nut to spec, and then reinstall the locking nut and torque it to 85 ft. lb.
The new Prop Double Nut Kit (P/N 8M0179579) can be ordered from a Mercury Racing Authorized Dealer, and will replace the single-nut hub for all Mercury Racing outboard propellers.
floatingphil is offline
TVMNick (09-14-2022)
Old 09-14-2022, 10:43 AM
  #32
I like Yamaha's design with the castle nut and pin.
I had a 2.5 liter Sportmaster that a previous owner had converted to that style. Worked like a charm.
Markus is offline
Old 09-14-2022, 01:51 PM
  #33
How are the 300Rs doing? Thinking about making the switch. Id like to get Rs instead of standard to make sure Im getting a little speed bump over my Suzuki 300s.
hogie roll is offline
