300 outboard longevity Yam vs Merc. V6 vs V8
Looking at these two engines. 6 vs 8. The v8 has a 10 mm smaller piston and 4mm less stroke and is .4 liters larger and the Merc runs on 87 octane vs 89 for the Yamaha.
I would think the Merc should live longer as rom to rom the Merc pistons travel slower and weigh less than the V6 yamaha. there is a bit of a weight diff with the yamahas being heavier. i also like the larger 5.44” lower on the Merc but at the same token I can’t find the dimension of the Yamaha 300 lower unit. price in both engines within a few hundred bucks Anyone like to give me some feedback. Thanks in advance Rm. |
Lots of good upgrades on the 2021 Yamaha 300. Gear case is 4.75" on the Yamaha, but materials used in cylinders and gear case etc. are of superior quality to Mercury.
The Helm Master EX option with autopilot and digital built-in electric steering is handy too. Your current marina, which is Yamaha biased will continue to put up with you, and last but not least, Yamaha is blessed by Virgen Del Carmen in Colombia. https://cimg2.ibsrv.net/gimg/www.off...d4ce47ab5d.jpg |
Originally Posted by larslindroth
(Post 4805155)
rm, did you check the classifieds here
(Post 4805220)
I have a pair of 4.6L V8 Mercury 300's on my pontoon boat and they are impressive engines. I run them wide open often and don't stress it one bit. The other thing I really like about them is they are extremely easy to work on, the oil drain, the oil filter catch basin, and the removable cowl are super nice for maintenance if you do it yourself. Yamaha has an amazing reputation though and I'm sure they are excellent engines too.
Originally Posted by TVMNick
(Post 4805223)
| All times are GMT -5. The time now is 05:15 AM. |
