Originally Posted by F14A water jet
(Post 4813726)
I am surely no expert BUT my research showed that VP Octanium® Unleaded Octane Booster had some long-term maintenance concerns/issues (maybe associated with O2 sensors and car catalytic converters). Also, Boostane (and most brands) allows you to tailor your octane to your needs with mix rations (Oz. per gallon of gas) depending on the octane. I did a spreadsheet of costs and Boostane was the most economical with the least amount of negatives (followed by Aces IV).
https://cimg1.ibsrv.net/gimg/www.off...e3d25d056f.jpg Another dumb question... Again, since I don't need triple digit octane, I can actually get what I need from the pump. But, as I stated, most pumps don't have 91, and the 93 seems to suet up the transom something fierce. Could a guy get away with pumping equal amounts of 89 and 93, and expect 91 octane as a result? Obviously, I can do the math, but does the chemistry work that way? Thanks. Brad. Model Machine and Precision LLC (937)545-8991 |
(Post 4813743)
F14A,
Another dumb question... Again, since I don't need triple digit octane, I can actually get what I need from the pump. But, as I stated, most pumps don't have 91, and the 93 seems to suet up the transom something fierce. Could a guy get away with pumping equal amounts of 89 and 93, and expect 91 octane as a result? Obviously, I can do the math, but does the chemistry work that way? Yes, equal parts of 89 and 93 will get you 91 octane. And......please stop posting your business info in your posts unless you wish to purchase a Commercial Membership. |
(Post 4813743)
F14A,
Another dumb question... But, as I stated, most pumps don't have 91, and the 93 seems to suet up the transom something fierce. Could a guy get away with pumping equal amounts of 89 and 93, and expect 91 octane as a result? Obviously, I can do the math, but does the chemistry work that way? Run as much octane as you can, octane is resistance to detonation, that`s it. It doesnt burn slower or faster like the old wives tales would have you believe. If your engine is set up to run 89 octane and you put in 116 you wont lose or gain power. There`s an entire episode on this (engine masters). Boosted you need to see what your final compression ratio is and that determines if you need more octane then pup gas can provide. There`s more to it but here`s a general rule chart:(bosted) https://goodvibesracing.com/Compression_Ratio.htm as an example if my engine is 8.0:1 and I`m running 10 psi I should be running some boostane because pump gas is not going to cut it . |
Dan most 500 efi and 525 boats have noticeably more soot on the transom with 93 than 89, and many have tested to run a tick slower with 93. That said, Mercury has notoriously rich tunes.
Dan just ordered two 5 gallon buckets Boostane Prof. thru Boostane. Delivered $599.99. Bought 5 gallons through Amazon a few weeks ago and it was $425.99 delivered. So for $175 I got an additional 5 gallons. Super deal! Took me a few times to get the BOGO code right. Code has a zero at end. I tried to make it an O. Thanks for the heads up!
Originally Posted by bob
(Post 4813782)
I bought 12 cans of the marine for $277. Their email said it was only for black friday deal so I`m glad it still works . I may order more |
Originally Posted by Unlimited jd
(Post 4813775)
The outcome of this episode where they dynoed the same engine on 87 thru 116octane race fuel and optimized timing and fuel... it made almost no difference in power . https://www.facebook.com/watch/?v=744265356291138 |
Originally Posted by ICDEDPPL
(Post 4813796)
That`s interesting. Any idea why octane would cause sooting ?Does not compute to me.
The outcome of this episode where they dynoed the same engine on 87 thru 116octane race fuel and optimized timing and fuel... it made almost no difference in power . https://www.facebook.com/watch/?v=744265356291138 Many set ups (as a whole, not just boats) first time over , say, 60% throttle , each run period, will do quick knock sensor test. Will go to preprogrammed timing # where it shoukd knock. If it doesn’t the computer will run at a lower timing table thinking the knock sensor system isn’t working right. Some efi programs will also add touch more fuel. Thus why you typically don’t see a carb or aftermarket efi do this, with just octane change. |
Oh that is interesting but makes sense !!
Originally Posted by SB
(Post 4813797)
Typically factory EFI.
| All times are GMT -5. The time now is 07:20 AM. |
