-   -   What's on the winter upgrade list? (https://www.offshoreonly.com/forums/general-boating-discussion/374155-whats-winter-upgrade-list.html)
F-2 Speedy 12-08-2021 03:19 PM
Second winter in a row engines are staying in the boat ....:drink:..... but I have some new props to test come spring time...........now if I could only get this Vette to run....:faint2:
bencini231 12-08-2021 07:01 PM
Originally Posted by Cms51 (Post 4814410)
How much power are you putting threw the scxs?
We are going to stay in the 850 range on these for now. I believe once you get close to 900hp the factory cooling needs to be upgraded.
bencini231 12-08-2021 07:05 PM
I think you'll be pleased with those props, that you have for testing. I finally got my herings and maximus props ready for some testing very soon. I've been around Vettes all my life and if I were closer I'd come by to give you a hand.
bencini231 12-08-2021 07:17 PM
Some fuel tank winter upgrades finished today. Factory pickups vs custom pickups for added fuel flow to feed the SC's.
https://cimg2.ibsrv.net/gimg/www.off...1c145ed37c.jpg
https://cimg3.ibsrv.net/gimg/www.off...3fd83bff4d.jpg
https://cimg0.ibsrv.net/gimg/www.off...3dd81773d1.jpg
the deep 12-08-2021 09:52 PM
I'm thinking about sanding and polishing the inside of my BDS scoop for max airflow. Anyone know where I could get a nice clean looking screen/flame arrestor made to mount in there? I chose to run this setup because of the heavy mist that comes up the transom so as to keep it out of the rear carb. Old school but cool.
https://cimg6.ibsrv.net/gimg/www.off...4bb5187e4.jpeg
carnutsx2 12-08-2021 11:58 PM
I got the cockpit canvas replaced already, sending the prop out to be touched up, new cockpit speakers add two more , a sub and an amp, replace the drive hub i blew the last trip out and add a mount for the spare tire on the trailer
dykstra 12-10-2021 06:44 AM
I’m having a new cockpit cover made.
IGetWet 12-12-2021 06:36 AM
I’ve been avoiding posting on his thread cause it might make me sick...
Replace the lighter blue panels probably with carbon fiber panels since I redid the interior last winter a much darker blue. Move garmin 7” from helm to passenger side.
Add new 9” garmin to helm which requires sliding the gauges outwards a bit
Replace toggle switches with blue water push button switches you can actually see at night
New stereo head unit in cabin and remote at helm
New amp that actually works
Replace 6.5” speakers in cabin with speakers that actually work.
Pulled apart throttle/shifter to rebuild/regrease. Old grease was very hard.
Either fasten down existing floor in cabin or cut out and replace. Haven’t decided which way yet. Loose in one spot and when you step on it right you can hear the clunk from being loose.
Rebuild step down into cabin to remove vent for AC that’s been removed.
Replace cabin floor carpet with marine mat or similar.
Finish new white and blue lights in cabin.
Finish wiring LED speakers
Finish wiring Drive sync for presets
Finish wiring LED cup holders
Clean up wiring to Simrads in bolsters a bit
As of yesterday, pull all polished or chrome parts, except steering wheel, and have them powder coated black or charcoal.
Valve lash and other less important things, lol
https://cimg7.ibsrv.net/gimg/www.off...fcf9ee61c.jpeg
https://cimg8.ibsrv.net/gimg/www.off...dbb8e59e8.jpeg
https://cimg0.ibsrv.net/gimg/www.off...ba3b3fb15.jpeg
https://cimg1.ibsrv.net/gimg/www.off...e83e2eb2f.jpeg
seafordguy 12-12-2021 08:41 PM
4 new indicator Cables
New AC ( if I can ever get it shipped)
New headliner (if someone will come do it)
New water pump mounts
Might play with the adjustable timing a little and see if I can get the idle down a bit and get them leaned out a touch.
All the easy stuff has already been done last weekend - oil, filter, drive lube, plugs.
New water pump and thermostats for the little 16' Donzi.....
87MirageIntruder 12-15-2021 10:44 AM
I'm installing a larger oil cooler, and my bravo drive is over getting rebuilt by Dick Tryce (everything was worn out).
