-   -   Pre-Ceramic Coat cleaner (https://www.offshoreonly.com/forums/general-boating-discussion/374660-pre-ceramic-coat-cleaner.html)
seafordguy 01-29-2022 07:42 PM
So last winter I used a ceramic coat product instead of wax and was relatively happy with the results.
What's a good cleaner to use prior to applying? Obviously I have a little black streaking still on the gel in certain areas. Last year I used maguiars oxidation remover to get it clean, then applied the ceramic coating. That's not the best process, was hoping there is a better cleaner you guys can recommend.
Second - what ceramic coat product is everyone using? I bought one off eBay last year, and again, was pretty pleased, but would like to see if there is a better product this year....
seafordguy 01-29-2022 08:37 PM
Anyone used Glidecoat? Some decent feedback on forums. Looks like they will perform ceramic coating and also sell the product....
offshoredrillin 01-29-2022 08:47 PM
https://cimg0.ibsrv.net/gimg/www.off...c6d1842c38.jpg
https://cimg1.ibsrv.net/gimg/www.off...87f3368ea6.jpg
https://cimg3.ibsrv.net/gimg/www.off...3a83dc24b6.jpg
https://cimg4.ibsrv.net/gimg/www.off...34c8466d7e.jpg
https://cimg5.ibsrv.net/gimg/www.off...a5c036a509.jpg
https://cimg6.ibsrv.net/gimg/www.off...234607d761.jpg
I did mine with Xpel Marine coating.. its all I use at the shop too. most of the spray and wipe stuff will only last a season.
precisiondetails 01-29-2022 08:53 PM
P&S Coatings and all products.
the true process is to do your polishing and then use a prep spray before laying the coating down. It is to remove all the raw chemicals in the polishes and you want the surface completely clean/fresh so the coating will adhere for maximum efficiency. After the coating you should use a topper for that final slickness, it is also the product that will mainly be the maintaining chemical for the coating.
1MOSES1 01-30-2022 07:55 AM
We used isopropyl alcohol mixed with de-ionized water to prep after buffing and wet sanding.
hoodoo 01-30-2022 09:02 AM
‘Drilling, who did you say did your paint job after the guy in south fl frigged it up?
offshoredrillin 01-30-2022 09:05 AM
thats what most of the cleaners are, after you do the prep work you need to get rid of the polishes and left over contaminants, or they form a block for the ceramic.
offshoredrillin 01-30-2022 09:07 AM
Maryland offshore performance and Grafik efx, chris dilling did the design and paint work
1MOSES1 01-30-2022 09:21 AM
The spray and wipe stuff may only last one season but it’s 100x easier to apply and 100x more forgiving.
we used car pro quartz on the bottom…it works good. It’s just a PITA.
I would recommend a good spray and wipe to anyone who is considering making the change before spending 4-6k to have there boat done.
even then I might still opt for the spray and wipe.
seafordguy 01-30-2022 02:06 PM
What ratio Moses?
