Engine silent option
Recently picked up a 1999 29 Scarab. I was told it has engine silencers on it. Can anyone tell me how I turn that on and off?
Thanks! |
Welcome to OSO, you will need 9 more posts for permission to post pictures. They don't need to be meaningful.
Then post pictures of your setup (engine compartment, transom and dash) and someone will be able to help |
Originally Posted by resurrected
(Post 4826705)
It may just have mufflers or it may have Silent Choice exhaust. Silent Choice would have switch on the dash.
If you have Silent Choice, Captain’s Call or similar, it will have a toggle switch on the dash. Last one I had read “open” or “closed”. Lift your engine hatch and look at your exhausts, they have the manifold with pipes going straight out the back through the hull and also pipes diverting downwards to to the bottom of tne sterndrive. That is silent choice/captains call etc…….
If the pipes just go straight out through the transom only, you may still have mufflers fitted which are not switchable. Have a look at the outlets from behind the boat. Are they empty pipes or do they have a larger pipe fitted around them? They may have baffles inside the pipes? Not sure if Scarab ever used the big mufflers like some Sea Rays had, exhaust came from the manifold and down towards the sides of the boat and into a large round sealed muffler (Looks like a big bucket) then out through the sides of the hull. Good luck. 🙂 RR |
I am going through this right now its such a pain
Originally Posted by rak rua
(Post 4826778)
Not sure if Scarab ever used the big mufflers like some Sea Rays had, exhaust came from the manifold and down towards the sides of the boat and into a large round sealed muffler (Looks like a big bucket) then out through the sides of the hull.RR
| All times are GMT -5. The time now is 11:58 AM. |
