-   -   Plugging flush mount cleat drain hole (https://www.offshoreonly.com/forums/general-boating-discussion/375315-plugging-flush-mount-cleat-drain-hole.html)
seafordguy 04-06-2022 08:56 PM
Any reason I can’t just plug this drain hole up? I have two small cleats that I’d prefer to just plug. I assume the water would just puddle and then evaporate? If so anyone know what fitting it is? Doesn’t appear to be 1/8 NPT it’s very coarse thread…..
https://www.boatoutfitters.com/flush...16=772&215=866
seafordguy 04-06-2022 09:01 PM
Just realized it was an Accon Marine product. I’ll call them tomorrow…..
scarabman 04-07-2022 06:22 AM
Winter/freezing would be the only consideration, in my opinion. Why not just run drain hoses?
Sydwayz 04-07-2022 09:06 AM
No reason that you can't, just make sure you rinse it out with fresh water.
Griff 04-07-2022 01:00 PM
Most of my pop up cleats have the drain tube plugged
seafordguy 04-07-2022 05:44 PM
Come to find out they have been draining directly on the foam behind my upholstery. there is a wood/fiberglass mount directly under it so running a drain tube would be hard - probably not enough clearance.
I’ll just plug
