-   -   Pulse drives? (https://www.offshoreonly.com/forums/general-boating-discussion/37624-pulse-drives.html)
MassiveThunder 11-25-2002 01:06 PM
Pulse drives?
Is anyone here use them?
seanclong 11-25-2002 01:38 PM
I just saw some this weekend for the first time. I'm very curious to find out more about them. Look cool...
MassiveThunder 11-25-2002 03:42 PM
What type of boat were they on?
thunderdan 11-26-2002 08:40 AM
I would also like to see if anyone is using them in higher hp application with a large boat.
seanclong 11-26-2002 02:52 PM
They actually weren't on a boat. There was just a display of the drives hooked to a motor at my marina. That's why my curiosity was piqued.
MassiveThunder 11-26-2002 04:05 PM
Well I guess I will have to be the first one to try them.I think the 37 Active Thunder will run rather nicely with them hooked up to some 525's.Projected speeds into the mid to upper 90's.Oh and did I mention that it will be RELIABLE.
MassiveThunder 11-27-2002 06:08 AM
It will be a while. There are a few 37's to be built before mine.
Jassman 11-27-2002 06:55 AM
Hey Al, are you coming to the Key west run in January, if not we are planning a Destin Run in March, your boat should be done by then, (stir the pot) Sandy says hi to Wendy:D
MassiveThunder 11-27-2002 06:58 AM
I may go on the run if I can hitch another ride.My boat will not be done untill late summer.I am hoping my 37 will turn into a 42 by then.
GregP 11-27-2002 07:09 AM
Curious as I can't tell from their site, how do they transfer power down from the engine centerline to the input shaft? How do they reverse one drive, in the motor (reverse rotation) or ???
-Greg
MassiveThunder 11-27-2002 11:01 AM
tranny
Gary Anderson 11-27-2002 11:08 AM
What tranny do they reccomend?
What reduction ratio?
Gary
imongo 11-27-2002 01:55 PM
Hi Massive,
Cat is right. I am putting a 1500 dual Pulse Drive on my 35 Cafe Racer. I have 475 hp 454's. Figured I'd pickup around 5-7 on the top, but more importantly, nothing to break. My drive will be here on Monday and will begin the project then. I figure it will take 7-10 days (you know how it goes when you take the motors out) and will be posting pics through out along with before and after performance results. You are building exactly what my next boat will be (in a couple of years). A 37 (or maybe 42) AT AVH with Pulse Drive. I was thinking 500's, but will probably end with 575SC's or something similar. I will keep the board posted as the project progresses.
Mongo
Oh, Gary... I am using ZF63A's. 1.53 ratio. PSI recommends ZF or Twin Disk. Greg, to reverse rotation, you just flip the cable and run the tranny in reverse.
GregP 11-27-2002 02:09 PM
Originally posted by imongo . Greg, to reverse rotation, you just flip the cable and run the tranny in reverse. [/B]
imongo - I know my trans (BW for a TRS) doesn't like to run at power in reverse. The ZF's must be built different. Do the trannies also include the vertical drop required to get the output shaft at the transom lower? Any idea how much the parasitic power loss difference is for the trans which is running in "reverse"? Gear "theory" says at least 3% for each gear stage, practice is usually higher.
-Greg
Steve 1 11-27-2002 02:25 PM
My thought on the subject is the use of a reverse rotation engine it’s not a big deal. As we know prices are paid for any change along the power transmission line such as in gear reduction/multiplication/reversal of rotation.
What do the gear/transmission suppliers have to say about the higher RPM side of the reverse Equation? With diesels really no big deal there as the RPM parameters are on the low side.
imongo 11-28-2002 09:15 AM
The ZF's are designed to run either direction. It is just a matter of which direction you attach the cable. There are provisions for either direction.
Yes, the ZF's have an offset down to accomodate the need to have the output shaft as low as possible.
As far as power loss goes, it is around 10 hp (I think). It is less than the loss from a Bravo and a lot less than the loss on a TRS. The other thing to consider is you have reduced the under water drag to almost nothing (just a small piece of the tips of the rudders and about 2" worth of skeg on the strut).
Dan, the Pulse 3000 is rated to 1600 HP and 6100 lbs of torque. Even at that level, they carry a 5 year warranty! If I were in the market for a big, high end boat, I couldn't justify using anything else. #6's? Spend all that money just so you can get "surface drive" performance? Why not just get a surface drive?
Mongo
Stillcrazy 11-28-2002 09:27 AM
pulse drives
An (A) class boat raced in Ft. Myers a few years back. Saw the boat at a Marina in Marathon Fl. Got a pic somewhere and might be able to I.D. and talk to someone that raced it.
I inquired and talked to Pulse Drive engineers.They were very helpful. I'm tired of all the hassel with I/O 's.Simplicity also offers this kind of arrangement.
Jassman 11-28-2002 09:56 AM
Pulse and Avh are to A.T. reliable and awesome ride;) :D Thats the way to go on A.T.'s new 45 Avh:D
imongo 11-28-2002 10:57 AM
Stillcrazy,
Yeah, the race boat is a 29 infinity. It won all the races that year except one in which it finished 2nd. Then they promptly outlawed surface drives for A class. Some of the interesting things about that rig...
The boat was using the wrong size (too small) drive for it's HP. It had a 1500 series and should have been running a 1750. They ran the whole year with NO faliures. One of the races, the crew forgot to put the trim pin in. They had no trim at all! Ran the whole race with the drive just "floating". They won the race anyway. It was kinda funny to see the news video footage and hear the announcer talk about it, watching the drive going up and down with the seas. Another interesting note is that the crew doesn't throttle the boat except for turns. They would simply drop the hammer and let it fly. The crew would trim the drive up and down depending on how much bite or speed they needed (turns again). When the boat would catch air, they just let the rev limiter take care of the motor.
Like I said, I will be reporting all along the project and post the performance figures for my boat.
Mongo
