DIY Gantry Crane
https://cimg2.ibsrv.net/gimg/www.off...49eee9f7d5.jpg
https://cimg5.ibsrv.net/gimg/www.off...cf5cf106af.jpg https://cimg8.ibsrv.net/gimg/www.off...f59a8d275d.jpg With mechanic prices thru the roof i refused to pay someone $1500 to remove my engine. I work a lot and it would take more time if i did the job but to hell with it. I've removed several engines and put them together but had a different job that allowed me more personal time. Now i just flat out refused to dish out so much money to have the engine removed and installed. Did some research and built this contraption to get it done. |
someone post the pic of the gantry using ladders and propane tanks please
I think your gutters need cleaning!:party-smiley-004:
Nice work, but remember, you need to be able to move fore / aft and side to side as you pull each engine. How do you plan on accomplishing that?
You could make a trolley that rides across the top beam with a couple of tires from HF attached to 2 steel plates through bolted with black pipe. Looks like it would work to me. What's an engine weigh, 500-600lbs?
A dressed 500 efi is 900 ish pounds
Originally Posted by scarabman
(Post 4838020)
Originally Posted by ThisIsLivin
(Post 4838034)
I did something very similar many years ago when changing out the engine in a diesel Audi I had at the time. Ended up doing a couple of friends' cars, too.
Isn't that about $4K worth of wood though?! :lolhit: JK! Looks good.
| All times are GMT -5. The time now is 12:47 PM. |
