-   -   Can a carb engine have blower surge or only injected engines? (https://www.offshoreonly.com/forums/general-boating-discussion/376916-can-carb-engine-have-blower-surge-only-injected-engines.html)
Wally 08-30-2022 08:33 AM
I like the sound of it, but i don't think I'd like to actually have a car/boat with it! :D
From what i've been told, basically the tuning is off on the engine and the motor is cycling from rich to lean.
On a carb application ive been told its cause the carb has not been boost referenced and its screwing with the power valve.
PROP STAR 08-30-2022 08:47 AM
Power Valves don't open at idle , and Rod's motors back in the day at Pro Tech Dyno Shop were definitely B@@ST reference 3 circuit
ICDEDPPL 08-30-2022 11:15 AM
Originally Posted by speicher lane (Post 4843261)
Isn't the Blower surge Button vid ICDEDPPL's?
+1 on the bad tune but it is sooooo cool to hear on big mills! (Dan had the answer to cover both worlds with "the button")
I added timing with the "button" ....that adds rpm , Holley sees that and closes the IAC/drops timing .... rpm falls too low, Holley tries to get back to commanded idle rpm opens IAC and adds timing , over shoots ... and repeat .
you can see timing and iac counts in the vid. (yellow is timing and to the left is IAC count.)
PROP STAR 08-31-2022 07:56 AM
https://www.youtube.com/shorts/imC8WR30ie0
Sounds BADA$$ Brutha :ernaehrung004:
tommymonza 08-31-2022 11:14 AM
Annoying as Hell, kinda like Harley guys sitting next to you at a stop light continually crackin the throttle.
Brad Christy 08-31-2022 11:18 AM
Tommy,
Opinions vary.....
Thanks. Brad.
(937)545-8991
tommymonza 08-31-2022 05:23 PM
Originally Posted by Brad Christy (Post 4843443)
Tommy,
Opinions vary.....
Thanks. Brad.
(937)545-8991
I Love the sound of a healthy V8 but that Rev and die not so much and to me most Harleys sound like a lawn tractor with a bad muffler , reminds me of the kids who put Cherry bombs on his grandmas 6cylinder Nova and thought it was Badazz
I'm a little touchy as I have some mouthy little fatherless bastard neighbor kid continually revving up his turbo Subaru at all hours of the day. Damn thing sounds like a 4 cylinder with 2of the plug wires switched .
