-   -   Garmin Echomap P79 transducer (https://www.offshoreonly.com/forums/general-boating-discussion/377297-garmin-echomap-p79-transducer.html)
Priobe 10-05-2022 07:15 AM
Hello
I’m hoping someone can help me on this issues.
I have a Garmin Echmap94SV plus unit and using a Airmar P79 transducer.
I installed the transducer in the recommended area with RV anti freeze but not getting a depth reading. I tried contacting Airmar and they are no help and called Garmin with no help either.
I have seen Airmar makes many various models under the P79 transducer. Airmar indicated it should work.
apparently there is no way to test the transducer according to both manufacturers.
Before I purchase a Garmin similar unit I figured I would reach out to you all for advice.
thanks in advance
redsled33 10-05-2022 09:26 AM
Mine quit Working on my Garman till we had to go into the active captain and do an update then it started working again I thought for some reason my transducer was bad but apparently just needed an update
