-   -   Mercury's Big Announcement Today (https://www.offshoreonly.com/forums/general-boating-discussion/377700-mercurys-big-announcement-today.html)
Wildman_grafix 11-15-2022 02:53 PM
Can you imagine if they used the same amount of resources (engineering) to design a modern I/O in the 500-700 HP range?
Of course the power head has no idea its strapped on the back or in a bilge.
DrFeelgood 11-15-2022 03:05 PM
Maybe someone will do the reverse of Seven Marine. Take an OB powerhead, design a coupler and some exhaust, lay it down and bolt it in!
Mbam 11-15-2022 04:35 PM
Originally Posted by jadento (Post 4851511)
How are they going to keep the gear cases alive when the HP goes up?
That was my first thought.
Looks like they have a new lower unit 6.4" with larger gears. Also uses a new larger diameter Revolution prop.
Should be interesting
thirdchildhood 11-16-2022 08:38 AM
By having multiple gearcases in the water splitting the load.
hogie roll 11-16-2022 02:04 PM
The 565 and 860 aren’t enough for you?
Hard to justify the investment with the I/O market going cold.
techman 11-16-2022 03:03 PM
I had the same thoughts about adapting these powerheads to stern drives. There was a time when outboards crowding the transoms was frowned upon as an aesthetic. But sticking motors back in bilges just from a manufacturing and rigging standpoint faces an uphill battle. The outboards are winning no doubt.
I'm seriously considering moving over myself. I love my big blocks....but I deep sigh every time I have to do something on them.
Wildman_grafix 11-16-2022 03:09 PM
I'll give you the 860, but the 565 is just a old BBC.
Compared to the tech in the outboards its a dinosaur.
But I know performance V's are dead so really do not expect anything to happen. I will say from a aesthetics point of view OB's just never flow. But its not like these V-10's are aimed at the small performance market as much as the big heavy CC market.
SB 11-16-2022 04:12 PM
New Unveling.
More outboards. Got it. :wink.
compedgemarine 11-16-2022 05:09 PM
at 700 lbs each I can see the transom repair market booming for guys with 4 of these on a bracket hanging off the back
hogie roll 11-16-2022 06:34 PM
The verado has weighed 662lbs for 20 years. These are +30lbs each. The 450 is 700.
Havent seen any damaged transoms in a while.
