OT-2500 HD Tires?
What are the largest size tires that anyone has installed on a 2002 Chevy 2500 HD without any suspension modifications? I'm looking at upgrading from the small 245's to something that fits the wheelwells. Any suggestions? Thanks.
LT285/75R16
Are the 285's with the stock width rims?, I'm will be changing to some 16 X 8" rims.
I run the 285's on my stock rims (BF All Terrains, 2002 2500HD) I would not buy any other tire!!
OG:cool: |
You can put LT305/7516's on it,,,, fair warning though, I did it to mine and it handled like chit, ,,,,, to much side roll for me, I didnt like the way the ass wandered while towing so I went back to the stock size,,,, I would maybe go 265's if it was me,,, there was a good thread about this a while back with some pics of tire changes. I cranked the torsion bars just a tad to level the truck with the bigger tires,,, it looked great,,, just wasnt for me.
http://offshoreonly.com/forums/showt...hreadid=34139&
The rims you have now are 16x6.5. You should be just fine on the 285s with 16x8 rims; but that does depend on the backspacing. I have a 2500 Avalanche, similar to your HD, and just went through all of this. I went with ARE 16X8 Outlaw II rims, and 265 Cooper Discoverer ATs. See my thread above for more details. The BFGs have a more square shape to them, especially at the contact patch where you are going to incur wheelwell rub if you go too big (wide). I suggest going to the manufacturer's website of the tires you are looking to buy, and looking at all the dimensions of the tire on their spec sheets. I did this and went with my best guess, along with guidance from my favorite 4X4 shop. I ended up with 265 Cooper Discoverer AT. We did have to crank up my front torsion bars a bit to give some clearance. I did not lose any ride quality. I still have just a touch of rub when reversing at a full lock turn. Nothing I am concerned about. Heck, my Trans Am even rubbed from the factory. Your HD has wider wells than my AV, so you should be fine. I highly suggest the BFGs (expensive and hard to get right now) or the Cooper Discoverer AT. I have had both, and currently the Cooper Disc ATs are fandamtastic in handling, traction, and towing. I also added rear airbags, which is like having a fully adjustable rear sway bar for $300 bucks. Good Luck. |
BFG'S
285's A/T they add a litte height and fill the wheel wells up.
I got 305/70-16 Goodyears on 8x16 Eagle Alloys under my Tahoe:eek: . Looks GGGRRRRReat. Handles good. No lift or messing with t-bars and nothing touches:cool:
Got 60k miles on them and they're still good for this winter.;) |
255/85R16 on stock wheels. It is a new size, ours are Dayton Baja AT's. Personally, they don't handle as well as I had hoped, the ass kind of wiggles around when the goose neck is on there. Our next tires will be 265/75R16's for less height.
Or, maybe we'll just get a dually. |
2002 Crew cab, changed the puny 245's to 285's , not a problem with rubbing, keep them aired up to 42 pounds, 65 max. Cooper Discovery
A/T, about 105.oo, each.:D |
1 Attachment(s)
285's will rub on 16x8's u8nless the t bars are raised, I had a body lift raised t bars 285's and 16x10's looked bad ass
mopower, what year is your Tahoe? I've got a 2002 Z71 and a set of 17x 8 Eagle alloys waiting for tires. Do you think the extra 1 inch of tire will matter?
2002 2500 265s not enough tire, need more go with a minimum of 285
Liquid Assett, my 2002 Crew cab with 285s does not rub.
Maybe I can save you some Money , Maybe not,, But at least I an give you some Ammo, for your locals!!
LT285/75R16 D RWL BFG RADIAL A/T KO $138.82 LT285/75R16 D OWL BRIDGESTONE DUELER A/T $106.00 LT285/75R16 D OWL G.Y. WRANGLER ATS $124.00 We have around 300,000 Tires in Stock, Passenger,Light Truck, Commerical!!!! I'll try to help you, If I can!! WWW.RUDOLPHTIRE.COM Call me 1-800-231-2295 ext 129 8.00am to 6.00pm Is it spring Yet????? Mitchell |
| All times are GMT -5. The time now is 08:23 PM. |
