-   -   Old School HP500 (https://www.offshoreonly.com/forums/general-boating-discussion/382938-old-school-hp500.html)
Griff 06-29-2024 10:43 PM
Originally Posted by SecondWind (Post 4901792)
Free horsepower I believe is the concept. You're not going to stress the moving parts anymore with larger displacement and it will make more power. The more displacement argument in a boat just keeps getting better when you start modifying the engine with things like forced induction.
And also more torque, usually with a flatter torque curve.
zzzzzz 07-05-2024 10:51 AM
Thanks for the advice guy's much to ponder
VetteLT193 07-05-2024 12:54 PM
You can get the same power with a bit more compression and less radical cam and save some money and increase the time needed to rebuild the top end. Plus that also leads to minimizing reversion issues. The edelbrock torker cam is a good happy step down that allows stock lifters and springs that are WAY cheaper than the 500 ones. I personally never quite understood why merc went so low on compression and so radical on the valve train.
Tartilla 07-05-2024 01:23 PM
Likely so they can spec a valve train service time, and have less issues with marine fuel issues leading to detonation.
They controlled what they could for the blue engines, where people would put up with a more frequent service plan.
VetteLT193 07-05-2024 01:41 PM
I think you nailed it. Just built for the masses vs individuals like me who are more anal about fuel, etc. I always just fill with costco premium and add star tron for the ethanol BS and never have had an issue
