-   -   Mercruiser Bravo Drive Continuous Alarm (https://www.offshoreonly.com/forums/general-boating-discussion/383031-mercruiser-bravo-drive-continuous-alarm.html)
Peter VanSickle 07-09-2024 04:12 AM
I have a continuous alarm. I have topped up the Drive Oil and the alarm is still sounding.
Any suggestions? Thank you
BBYSTWY 07-09-2024 06:04 AM
If the bottle went empty the float is probably stuck on the bottom of the reservoir. Take the cap off and fish around in there gently with a screwdriver or your finger.
AllDodge 07-09-2024 06:38 AM
Disconnect the lube bottle to see if it stops
If it doesn't disconnect the temp switch and then oil pressure switch. The oil and temp switches have 2 wires on them and have a Tan/Blue striped wire on them
t500hps 07-09-2024 06:54 AM
Alarm sounds for low oil pressure, high water temp, and low drive oil.
I've found the oil can "gunk up" in an old drive oil bottle and while the level looks good, the oil does not flow at all. Empty/clean out that bottle and replace with fresh fluid.
Sydwayz 07-09-2024 06:55 AM
What is the powertrain setup? If it is Smartcraft enabled, best thing to do is hook it up to a Rinda or similar scanner to find out why the computer is sounding the alarm.
This is no different than troubleshooting a CEL on your car without scanning the OBD port.
seafordguy 07-09-2024 07:57 PM
Those Bravo drive lube bottles need to be cleaned every few years. The get chunky. Agreed, disconnect alarm ass see if that solves it. I believe the float simply grounds it and causes the alarm to engage…..
