-   -   Well...I guess the impeller shot craps... (https://www.offshoreonly.com/forums/general-boating-discussion/384155-well-i-guess-impeller-shot-craps.html)
bajaman 11-09-2024 04:30 PM
Took the trip down to Table Rock where my boat is stored to winterize it, hooked up the muffs and...no water coming out the exhaust. Tried a few times, decided to dunk it in the lake...same story. Evidently between the last time I had the boat out and it ran/cooled just fine, which was back in July, and now...the impeller shot craps. I have a new complete pump, but just didn't have the time to install it. Going to see if a local mechanic can fix it whilst in the storage unit. In 40 years of boating, I've never had this happen. I guess there is always a first time, huh?
Ryanw10 11-09-2024 04:46 PM
Had the same thing happen to a boat i tried to winterize a couple days ago. Boat ran fine 2 weeks ago, went to winterize and impeller fins broke and siezed the pump up. Had a nice belt squeal when the motor started up
F-2 Speedy 11-09-2024 05:02 PM
Friend of mine lives at the lake, if you dont find someone I could ask him, is it in Shell knob area ?
seafordguy 11-09-2024 09:54 PM
I change mine every year - one fall I changed them and they were more worn than I would have expected so I decided I’d always do them annually.
Maybe you got some Chinese knockoffs by mistake?
bajaman 11-10-2024 05:42 AM
Yes, Shell Knob area...actually more towards Viola. But I believe I have it covered...thanks!
bajaman 11-10-2024 05:52 AM
Yeah, not sure...the shop that did the impeller change last time normally uses only Mercruiser/Quicksilver parts that are (hopefully!) genuine.
I don't put many hours on the boat annually...maybe 15 hours or so, and have only 52 hours on the impeller...so it was ready for a change but the way it failed is something I'd not seen before...usually I'd notice a tendency for the engine to run slightly hotter at idle/no-wake speed if an impeller was bad. My last boat (Baja 208 with a Yamaha 454/Hydra Drive) had a Sherwood pump; I had that boat for nearly 30 years so much more experience with it.
seafordguy 11-10-2024 07:46 AM
Hope you get it fixed quickly….
bajaman 11-10-2024 08:22 AM
One of the problems with having the boat stored 300 miles away...I just can't easily go tinker or work on it.
madbouyz 11-10-2024 12:10 PM
A few years back I took my brother's boat (502mag) to get hauled . Ran and cooled fine from the slip at the marina to the haul out site.
An hour later on the hard , hooked up the hose to flush out and it wouldn't pump a drop of water . When the impeller was taken out of the pump there was little left of it . That was definitely a wtf moment. So it does happen I guess. .
snapmorgan 11-11-2024 06:37 AM
I always carried a spare seawater pump with me and enough tools to change it. I only remember using it once, but I sure did loan it out a bunch of times.
