C33 protective rubber boots
Does anyone know where I can purchase C33 cable rubber protective boots. The trim tab indicator cable shows what I need. Stainless Marine does not sell these anymore. Thanks for your time.
https://cimg1.ibsrv.net/gimg/www.off...190e13cd97.jpg |
Based off your pictures these at McMaster may fit the bill. The light duty heading.
I don't know how thick your originals are compared to what they call the light duty. It appears based off guessing the diameter of yours that'd be the only ones to fit. Otherwise, if your Google skills are weak maybe call this place and see if they have any shelf items that they've made before that would work. Flexible Industrial Rubber Bellows and Hydraulic Cylinder Rod Bellows – Crushproof® Tubing |
Originally Posted by cheech
(Post 4919613)
At the end of the day what are they really "protecting"
I`ve never had any such boots on any of my boats and I didn`t die. Hope that helps. |
Why would they be needed on Morse 33c cables???
Originally Posted by Griff
(Post 4919694)
https://cimg2.ibsrv.net/gimg/www.off...87fed6a742.jpg https://cimg5.ibsrv.net/gimg/www.off...aeca5d22ef.jpg |
Originally Posted by AmiableDave
(Post 4919697)
If the bellows are installed properly. They keep the salt/water from seizing the cable overtime. If they are installed with the plastic ties that come with them. They leak, holding the salt/water in place and the cable seizes quicker. Without the bellows the water does drain somewhat from the cable. And the cable still corrodes.
https://cimg2.ibsrv.net/gimg/www.off...87fed6a742.jpg https://cimg5.ibsrv.net/gimg/www.off...aeca5d22ef.jpg You could probably make Oetiker clamps work, instead of zip ties. Amazon has variety packs and bespoke pliers. Thanks. Brad. |
(Post 4919700)
Dave,
You could probably make Oetiker clamps work, instead of zip ties. Amazon has variety packs and bespoke pliers. Thanks. Brad. I called Formula boats to see if they had replacement bellows. Left message because everyone was gone. Still waiting on a reply. |
It sure looks like these would work in conjunction with oetiker clamps
https://www.ebay.com/itm/204568878374 |
Originally Posted by 36Tango
(Post 4919801)
| All times are GMT -5. The time now is 07:03 PM. |
