-   -   Injector cleaning (https://www.offshoreonly.com/forums/general-boating-discussion/384837-injector-cleaning.html)
PA.WOODCHUCK 02-23-2025 10:47 AM
Injector cleaning
brain fart... who does it? name starts with smith?
thanks
F-2 Speedy 02-23-2025 10:55 AM
Articfriends on here Smitty
PA.WOODCHUCK 02-23-2025 01:44 PM
any link to his webpage?
F-2 Speedy 02-23-2025 02:07 PM
Steve Smith
https://smittysengtrans.com/about-us
offshorexcursion 02-23-2025 06:42 PM
Yes Smitty is the best
ICDEDPPL 02-24-2025 02:50 PM
Avoid John Mossetti.
Smitty is the best .
Sydwayz 02-24-2025 03:07 PM
https://www.offshoreonly.com/forums/...-services.html
TexomaPowerboater 02-26-2025 08:55 AM
Is there really that much too it that you have to find someone special to do it? Can't you just trailer the boat up to the local lube shop for a fuel injector service?
Pnb 02-26-2025 09:48 AM
what exactly does your local lube shop do when you ask them for a fuel injector service?
F-2 Speedy 02-26-2025 09:51 AM
Originally Posted by Sydwayz (Post 4920851)
Why did you delete Dan and my posts in that thread ?? reason scammers......dont think so only the truth
Brad Christy 02-26-2025 11:17 AM
F2,
Saw that. Was wondering....
Thanks. Brad.
Brad Christy 02-26-2025 11:37 AM
TexomaPowerboater,
https://cimg0.ibsrv.net/gimg/www.off...8ebc6278f.jpeg
A bad injector didn’t do this, but it’s definitely on the menu with one. Gonna wanna be sure they’re in good shape.
Thanks. Brad.
F-2 Speedy 02-26-2025 09:24 PM
Still waiting for an answer
TexomaPowerboater 02-27-2025 09:02 AM
They hook them up to the same machines the dealerships use. I haven't done it, but am considering it.
What exactly do these referral's do that is so ground breaking?
F-2 Speedy 02-27-2025 09:16 AM
Why dont you call Smitty and get your answer first hand
TeamSaris 02-27-2025 10:07 AM
If you're in PA and want to stay semi local, marren fuel injection does fantastic work.
They come back clean and with a complete data sheet including off times etc.
Your local lube shop will not give you that. from their website- Your fuel injectors are the best place to find new power for your motor!
Getting Your Injectors Balanced & Blueprinted
Here is what we do:
  • Get a base line reading on them as they came out of the engine.
  • Information is downloaded into a computer (flow rates are in CC per minute).
  • Check spray pattern and reverse flow to check for contaminants.
  • Strip down the injector.
  • As it is being ultrasonically cleaned, the injector is opened and closed at a desired pulse width with a programmable fuel management system.
  • Injector is checked for any remaining cleaner.
  • Injector is brought up to a certain temperature and checked with a strobe to see the fuel atomization.
  • Electrical windings in the injector are checked with an oscilloscope and an ohms test performed.
  • Three hydraulic tests are performed before and after cleaning.
  • Perform a Leak Down Test
  • Install new pintle caps, o-rings and in-line filters
  • Supplied with a Computer Analysis Sheet
Once the process is complete, the key is for all the injectors to be within 0-2% deviation of one another. They should not exceed a 4% range between one another. The process improves:
  • Flow which is critical under high rpm in relation to horsepower
  • Fuel Atomization which contributes to the torque rise in the motor
www.injector.com
Ryanw10 02-27-2025 11:17 AM
No way I would trust a local lube shop to pull injectors out of my boat.
PA.WOODCHUCK 02-28-2025 04:53 PM
Related
Who's the go-to places for PCM/ECM issues, especially 496 555
F-2 Speedy 02-28-2025 06:55 PM
Mark Boos or Dustin Whipple...........^^^^^
SB 03-01-2025 05:01 AM
Lots of people cooking in restaurants out there too. They all have ovens/stoves.
So, yeh, what difference does it make. Sarcasm :)
So,,,,no. Many different injector machines out there and some much more capable and precise than others. Then, you have the operator and operators knowledge base and experience.
midwest272 03-01-2025 07:45 AM
I second Marren , they sent back the sheets with before and after performance for each cyl
The tech also mentioned there was a lot of stabil in the old fuel in the injectors which was true as I had not run it much for a few years
underpsi68 03-01-2025 10:45 AM
I sent my 496 injectors to BUP. He did a good job. Sent videos of before and after as well as sent me the old filters and Q tips he used.
I have since bought my own cheaper injector machine. It isn't on the same playing field as the commercial machines but it does give me good data. A problem injector shows right away.
On my street car i run e85. The bosch 210lb injectors i use are very sensitive for e85 to sit in them unused. Now I pull the injectors out and check them myself. It has been working very good for me.
ICDEDPPL 03-01-2025 12:18 PM
Originally Posted by PA.WOODCHUCK (Post 4921112)
Related
Again Not BUP, John Mossetti, he doesnt do any of the repairs, farms it all out and there was a fall out with the guy that actually fixes them.... all of a sudden he`s "too busy" to take on any more ECU repairs. Yeah , because the guy that actually fixed em told him to go pound sand.
He`s a pathological liar.
John fixed my Mefi for $500 and turned it around in a week.
https://obd2allinone.com/ecmrepair.asp
