Originally Posted by hpmaniac
(Post 4930412)
I have 2 brushless bilge fans that move a ton of air.
maybe that was just enough to help keep fumes down. Solid tight electrical connections and good plug wires. Makes you realize how important this stuff is. I run with fans on all the time to help move air through the engine bay. Blower fans would both pump out gas vapours and introduce oxygen, lowering the rich mixture to a more explosive and easier to ignite mixture. Just keep that in mind. OP with the manual bilge pump: nice peice of kit to have on board. |
The hand pump saved the day, some fuel line and hose clamps are also a good thing to throw in the spare parts bag.
It`s 2025 , no pics?
Honestly I was so panicked to get it fixed pics were last thing on my mind. The broken fitting is 200ft below water lol. It was 95 degrees and I actually got heat stroke fixing the thing. Yesterday I had to leave work early felt so crappy. Better today. Massive water and electorate fixed me up. I'm considering changing my fittings to steel. It was a 1 in million thing though I'd bet.
Originally Posted by ICDEDPPL
(Post 4930458)
Just wanted a picture of the broken part, wanted to see where and how .. so sorry, I didn`t know it fixed itself before pics could be taken.
(Post 4930470)
When you're in the Matrix...difficult to focus on anything but the immediate. Any fitting that has dynamic loading would be suspect over time. |
Stainless AN fittings, aseembled not pressed, re-usable.
304 stainless, but better than alum and steel for corrosion. I've seen alum AN fittings oxidize and powder away on the inside. https://www.anhosefittings.com/ptfe-...ing-4an-1.html Is there a better source that's 316L? Better pricing? |
| All times are GMT -5. The time now is 05:25 PM. |
