-   -   I Have A Freeze Frame Dvd Problem Could Someone Help Me Please (https://www.offshoreonly.com/forums/general-boating-discussion/38630-i-have-freeze-frame-dvd-problem-could-someone-help-me-please.html)
overbored 12-10-2002 02:25 PM
:( IT IS SO WIERD! ONE OF MY CLUB DVD'S WILL NOT PLAY SMOOTH IN MY SONY DVD PLAYER BUT WILL PLAY SMOOTHLY IN MY COMPUTER ALL THE WAY!?? In my Sony player parts of the dvd freezes and the plays, freezes/plays. When disc freezes there are dots on the tv. It's almost like a tracking problem on a vhs tape. Is there anyway to reduce the tracking? I know that te disc is fine, because like I said it plays fine in my cpu. Can someone please help me? thanks.
SmilingBob 12-10-2002 02:48 PM
Overbored,
Does the disk freeze at the same spot every time? If not you may need to clean the dust out of your player, just blow some compressed air in through the disk try and that works most of the time. If it is freezeing in the same spot check for finger prints or maybe some sort of mark on the back, ie water, oil ect... Try wipeing the disk off with a soft cloth from the center outwards in a stright line.
Audiofn 12-10-2002 08:12 PM
How old is your player. I have done some testing with the DVD's and have found that older DVD players tend to do this. Check for dust of course as has been mentioned.
Jon
MnFastBoat 12-11-2002 05:55 AM
consider yourself lucky on the computer
I cannot get mine to play on the computer.
as for the sony it would just be dirty
maybe even an alignment is in order
has the unit been moved?
I was told when I bought mine to really be carefull moving it around because the laser could get jared
WickedWon 12-11-2002 07:39 AM
I've talked to Jeff several times about this, his dvd's won't play at all on my high end Denon , he is aware of the problem but doesn't have an answer for it. So I'm watching his stuff on a 50" flat screen using VHS :mad: JD
spitfire1 12-11-2002 09:24 AM
Yep........I had the same problem with my Marantz DVD player......it wouldnt play on that one...but plays fine on my cheaper one......go figure....
overbored 12-11-2002 10:12 AM
AUDIOFN,
I just got the player 2 days ago ns315.
overbored 12-11-2002 10:16 AM
thanks mnfast yes it has just a little.
ssherman 12-11-2002 11:21 AM
I experienced the same problem on my sony on one of my disk but the other 8 are fine. Jeff offered to exchange it immediatly. I watched it on my cheap player in my bed room and then popped it back into my better player and it has been fine every since:confused: What ever the problem be assured Jeff will make it right.
wicked won whats up.
SmilingBob 12-11-2002 03:42 PM
OverBoard, Not sure if you got you DVD to play yet but if you have not talk to Jeff and I am sure he will make it stright with you. I had one deliveried to me damaged buy UPS and Jeff sent out a new one right away. He does care about his customers and knows what true customer service is.
overbored 12-11-2002 06:54 PM
EVERBODY, THANKS FOR YOU HELP! JEFF IS GOING OUT OF HIS WAY TO SEND ANTHER DVD TO ME. COOL!
