Originally Posted by boatnt
(Post 4934771)
in the automotive industry, Jasper does not have a good reputation, I would guess the same applies for marine
Fair enough. As a non-industry layman, I can only go by what I hear in passing. So why the bad rep? What are they doing wrong? Thanks. Brad. |
(Post 4934792)
BoatNT,
Fair enough. As a non-industry layman, I can only go by what I hear in passing. So why the bad rep? What are they doing wrong? Thanks. Brad. Maybe things have changed now and are better but I don't know |
Originally Posted by Leick238
(Post 4934764)
what about the AC DELFCO RAPID #1? Can you use those?
Originally Posted by boostbros
(Post 4934782)
i run NGK ur5 they work awesome
(Post 4934792)
BoatNT,
Jasper 502 motor
I checked all my plugs,wires and cap all look good. Idk when the cap and wires have been replaced. But boat runs fine for a while until it gets warm then it has a misfire around 3500 rpm’s. Any idea what to look into or what to dig into first?
(Post 4934878)
The plug wires should be kind of hard to pull off the plugs. If they pull off fairly easily, I'd replace them as well. |
Originally Posted by Griff
(Post 4934883)
Start with the basics. Plugs, cap and rotor.
1990 baja
Trying to replace my belts for a 502 big block serial number 0D336312 and my water pump belt has no numbers on it. Does anyone know what belt sizes I need to look for? If you can provide numbers for all 3 belts that would be great
Take them to auto parts store and have them match the size. Actual Merc belts are 3-5 times the price and no better.
| All times are GMT -5. The time now is 07:14 PM. |
