-   -   empty tank (https://www.offshoreonly.com/forums/general-boating-discussion/386949-empty-tank.html)
scippy 11-21-2025 09:41 AM
empty tank
So my fuel tank is dry after pumping all old fuel out ...any suggestions to avoid condensation for winter storage.
1HYPER1 11-21-2025 09:43 AM
fill the tank with fresh fuel and add stable to the fuel for the winter storage
scippy 11-21-2025 12:37 PM
I don't start running her til middle summer, wouldn't it be better to keep it empty then fill fresh fuel?.. shelf life would already have 8 months on fuel if I fuel now..
was thinking anything around for condensation absorbent to drop in now then fill fresh before use in summer.
Indy 11-21-2025 12:55 PM
For 40+ years I've just left the fuel in the tank wherever it's at, stabilized it and ran it the next spring....never an issue. Last year I hardly ran the boat, didn't put fresh fuel in it until August, no issues. Never really worried about any of this.
anger mgmt 11-21-2025 02:13 PM
Ditto. Been doing it that way for a long time. Never any problems.
seafordguy 11-21-2025 06:08 PM
mine sits sept to may or June every year. Never had any issues…..
Split the baby and put a half a tank in with stabilizer then fill with fresh summer blend next year…..
scippy 11-21-2025 07:07 PM
I'll fuel up with the half measure approach suggested by seafordguy.... my engines run on 89 at the pump, but doesnt gas as its stored lose octane?... it was great when I ran up on lake George I fuel up on non- ethanol gas stations.
No such non-ethanol thing here in Jersey......I'll fill up with a slightly higher octane & do the stabilizer ..thanx all!
496blower 11-21-2025 09:47 PM
I fill with alcohol free gas some stabilizer run the engine do oil change and good to go for next summe, unfortunately alcohol free gas over a buck a gallon more, never had a problem
bajaman 11-22-2025 06:05 AM
I have never, ever, in 50 years of boating heard ANYONE drain a tank on a boat for storage...
Triage 11-22-2025 06:13 AM
Learnt a bit from the thread
Bondo 11-22-2025 06:28 AM
Ayuh,...... Don't worry 'bout it,.... It'll be just as dry then, as it is now,......
Helmwurst 11-22-2025 07:26 AM
Why can't you just put some tape over the vent ?. I don't see an issue with that unless your tank is filled to the top of the hose and needs to expand and contract. JMO
outlaw511 11-22-2025 08:07 AM
I’ve been doing the same thing seafordguy does for the last 35 yrs. I fill up close to the end of the season, use it a few more times, usually leaves me with around half tank. Put stabilizer in it, store it for the winter and top off beginning of summer with fresh fuel.
techman 11-22-2025 08:56 AM
I always drain the tank(s) before winter storage. No sense letting perfectly good gas sit when I can use it in cars, toys, and power equipment. One spring, just for grins, I tried pumping the dry tanks again to see if any significant condensation gathered. None, bone dry.
Fresh fuel in the spring. Never had a problem in 25 years.
powerboatr 11-22-2025 10:16 AM
ditto
I fill 91 octane non ethanol
Add fuel stabilizer
I have to open it up maybe
During winter as my fuel guage stopped working right aftet i filled it up
hoping just a wire came loose
Have not been mobile enough to chase it
ICDEDPPL 11-22-2025 02:18 PM
He`s a little special
Markus 11-23-2025 09:07 AM
Condensation
If there is enough condensation for it to matter, you will be able to pump the water out before filling with fresh fuel in the summer.
scippy 11-23-2025 11:53 AM
just to understand, Gas was drained because it was old not because it was drained just for storage. I even considered polishing the old fuel, but for $750 to do so, I drained it into 50 gal. tank.
