Fuel sender
Anyone have any experience with this Holley fuel sender? It sounds like a good idea for boats. What are your thoughts???
Holley 19-250-1 Holley Easy Level™ Fuel Level Sender https://share.google/E3XINyQfNkQnJHgBc Padraig |
Haven't seen one of those before, but it sounds promising. Tried the capacitance type sender, couldn't get it to work right. Went back to orig float type that only works when it wants to.
Edit: Just noticed it says the output is PWM which I assume is Pulse Width Modulation. Doubt that will work with my current resistance type fuel gauge. |
I like it .
Isn`t most marine OHM resistance gauges thou? |
I don't know why my link doesn't work...Can someone smarter than me fix it, please.
Padraig |
Here you go, and thanks for the kind words, but i’m not. My bulb is dim, but it does work. :)
https://www.holley.com/products/gaug...parts/19-250-1 |
It says it works on classic gauges?
My gauge last time out decided to stop workinh have not had the mobility to get into it to see of its an easy fix of if sender died gaffrig makes a gauge that looks like my dash gauge It did mention highly reflective tanks could be an issue Mine is alum...its pretty reflective ....at least the outside 😁 the instructions do mention a gauge a few times I net for me a 1988 gauge is no go I supect mine are gauge, sender package |
Gaffrig has what I need under 150
gauge ,plus they will cut sender |
Originally Posted by powerboatr
(Post 4940201)
gauge ,plus they will cut sender They make the senders for pretty much every retailer and are about half the price |
| All times are GMT -5. The time now is 11:53 PM. |
