525 Sc With 200 Hours. Good Or Bad?
I'M THINKING ABOUT BUYING A FORMULA POWERED BY MERC 525SC WITH 200 HOURS. WHAY DO YOU THINK OF THESE ENGINES? WHAT SHOULD I LOOK OUT FOR?
Good motors if never overboosted. Came a little rich from the factory.
Run a compression check (or better yet, a leakdown). Look to see of you can tell if the heads have ever been off (broken paint on head bolts or repainted headbolts). A stock 200 hour 525 should NOT have needed the heads off unless it blew a headgasket (lean mix, too much timing, low octane fuel, or too much boost). Easy hopups are adding an intercooler and upping the boost to 6#. |
I have a pair in my 93' Cig with Blower Shops 250 blower, 240/hrs and don't burn a drop of oil.
| All times are GMT -5. The time now is 06:16 PM. |
