B Max vs Imco extreme sc ? >
Old 01-12-2003, 06:43 PM
B-MAX REPAIR
WILDTHING TAZ's Avatar
a little over a month a go B-MAX started shipping their own lower's. they are available in standard length OR 2" shorter. you can choose either when purchasing a drive.or you can purchase them separately, case only or complete lower with your choice of gear ratio. B-max does not use IMCO cases. in the past customers supplied lower cases when needed, not any more. RON BENDER
WILDTHING TAZ is offline
Old 01-12-2003, 08:12 PM
KAAMA's Avatar
I think I will eventually end up with a pair of IMCO Extreme SC's.
KAAMA is offline
Old 01-12-2003, 09:14 PM
Enjoy the show
Ron P's Avatar
I heard that the B-Max has trouble holding oil. No personal knowledge, just a rumor from someone that works on boats for a living.
Ron P is offline
Old 01-13-2003, 10:54 PM
totalmp's Avatar
Not true, B max, or an affiliate, did in fact order tons of lowers from IMCO w/ no vertical shaft, as the vertical shaft won't work on the B max. Also, IMCO lowers are all one piece aluminum, and are available in 1, 2 or 3" shorter. The Bmax is a very strong drive, but it is a gorilla that takes tons of HP to spin, one could just as easily put a speedmaster for the price. The IMCO is the best all around choice.
Steve
totalmp is offline
Old 01-14-2003, 07:04 AM
Jassman's Avatar
Thanks for your help Steve, talk to ya when I get back.
Jassman is offline
Old 01-14-2003, 11:05 AM
Mark,
What kind of power are you running?.
We have shipped close to 300 SC's last year, and have had very few problems. One thing you may want to consider is "Service". If you need to have it serviced, any Mercury repair shop can work on SC's, no need to send back to the manufacturer, which means very little down time.
IMCO
IMCO is offline
Old 01-14-2003, 12:04 PM
bobby daniels
Thumbs up
MARK ITS GOOD WHEN THE MAN. TRYS TO HELP YOU DIRECT LIKE ABOVE !!
M. JAMES SURE HOLDS UP BUT I KNOW HIS BOAT IS LIGHTER !!!
Old 01-17-2003, 07:00 PM
Wildthing TAZ, do you know what the cost is for a new B-Max lower with a nose cone. I have a two year old B-Max drive now. I had a nose cone installed on it and they didn't do a very good job.
Robbie Racer is offline
soinc
Drives and Lower Units
44
05-27-2009 09:20 AM
Sick Stinger
03-23-2008 04:03 PM
tomcei
Pantera
6
03-30-2006 05:17 AM
cbudge
24
09-19-2002 10:57 AM
www.gone
07-25-2002 09:40 AM
Quick Reply: B Max vs Imco extreme sc ?
