Just a couple of additional facts....
Suzuki XR 400 Model: SM 21 Body #: SM 21 10843 Engine: SM 20 Engine #: SM 20 18804 Not sure on the year.......'70's or 80's Also on the plug that the coils plug into there are 3 wires, of which only one is hot! Thanks for all the help! Aqua :frog: |
Umm, one is HOT?? As in 12v + ??
If so, you have an "automotive style" ignition. DC current to the coil and negative-triggered from points/CDI... Opposite of magneto/motorcycle/jetski/outboard style of coil. Therefore, you can use two LAWNMOWER coils... If you can get your hands on a schematic (maybe from the dealer) then scan it and post it... |
Originally posted by Aqua-Holic Just a couple of additional facts.... Suzuki XR 400 Model: SM 21 Body #: SM 21 10843 Engine: SM 20 Engine #: SM 20 18804 Not sure on the year.......'70's or 80's Also on the plug that the coils plug into there are 3 wires, of which only one is hot! Thanks for all the help! Aqua :frog: Is this it?? http://www.mfgsupply.com/m/c/01-116.html |
WOW!
That's CHEAP! |
To be honest, that is not the one that is in the sled now, but the one that is there, is not the original. I need to find a location that I can take the serial #'s to & find out the year, then I believe problem solved. For that price, I may just buy and and see if that will work. Thank you for all of the help!!!!
Aqua :frog: |
| All times are GMT -5. The time now is 11:46 PM. |
