What Ratio with XZ Upper and Sportmaster Lower
would you get ?
I have XZ uppers with 1.36 Gears and want to try the new shorter sportmaster lowers. What ratio would I get with an out of the box bolt up? |
Depends which of the sportmasters you use, they are avaiable in 15/19, 15/17 and 17/18 ratios. The overall ratio of your XZ (or any drive for that matter) is the upper ratio x the lower ratio.
A 1.36 drive = 29/27 (upper) x 19/15 (lower), so the possible ratios with your upper are 1.36, 1.217 and 1.137 Just like life, no single simple answer |
Thanks for the help.
A 1.36 drive = 29/27 (upper) x 19/15 (lower), so the possible ratios with your upper are 1.36, 1.217 and 1.137 Is 19/15 stated correctly here as it differs from the way you stated above? What would the poss. ratio's be with 1.5 uppers? Thanks. Sonny |
Oops,
Yes I reversed the numbers in the lower for the math to work the way I showed. It should have been 19/15, 17/15 and 18/17 in this case as both the upper and lower are reductions. A 1.5 XZ has a 32/27 upper , possible ratios are 1.5, 1.343 & 1.254 Don't forget that there is also a 30/23 upper, the resulting 1.65 ratio can be worth a few MPH on some boats but it puts a greater torque load on the lower unit |
Thanks again. This will help me with my project.
Oh, yea
Sonny, just sell that boat, get one with outboards, then you can run with me next summer.............LOL, what are you up too anyway, blowers?
Ask powerboat service , I'm sure they know!
Mark,
If I remember correctly I was in frony of your the WHOOOOL time at lake Cumberland! Fixin to go to Florida where it's warm for some testing. Lyron, When are you going to quit whining and step and get that new 36 Spectre? |
You gotta love OSO! SEE YA!
Sonny, you just have to keep the good deals coming so I can afford the 36' |
