-   -   Re-gelcoating bottom, any application tips? (https://www.offshoreonly.com/forums/general-boating-discussion/41687-re-gelcoating-bottom-any-application-tips.html)
Pure Energy 01-22-2003 08:20 PM
The bottom of my 1990 Sonic 30SS is in rough shape. There are many chips on the strakes, scracthes, and 2 long stress cracks. These are obviously below the water line and I want to fix to prevent future problems. I am going to grind open the stress cracks to check for de-lamination, fill with fiberglass, then re-gel the whole bottom. Since I will be doing the work on my back, under the trailer, will the gel lay flat if it is applied with a roller? How thick should it be. Can it be a little thinner since it is a top coat? I know there will be a lot of sanding involed, but I want to avoid spraying due to the angle it will have to be sprayed.
Thanks.
Nagivator 01-22-2003 08:49 PM
We regelled the bottom of a cig with a foam roller. It worked great. Just make sure you put the right additives in the gel so it can air dry.
