-   -   Corrosion Protection (https://www.offshoreonly.com/forums/general-boating-discussion/42733-corrosion-protection.html)
florida gator 02-05-2003 08:35 PM
I know I have seen info on this hear already. Just looking for the most up to date knowledge. I never paid much attention as my marina is 10 miles up a spring fed river. Now I will have a newly rebuilt engine so I want to start it out right.
What should I do to protect the inside and outside of my engine? How often should I reapply an inhibitor?
James
Iggy 02-06-2003 05:54 AM
Salt Away, from what I read, says that with repeated/regular flushings with their product it leaves a coating behind that'll inhibit further corrosion.
As for the outer surface, I don't know.
Merc has a product they spray on but it looks funky and dulls the engine color. Makes the engine look dirty all the time.
Anyone else have ideas??
florida gator 02-07-2003 08:49 AM
TTT, Come on guys. I try to help with advise when I can. I know there is more than 1 opinion out there.
BajaBennett 02-07-2003 10:37 AM
James,
Check out Salt-X as an engine flush @ www.salt-x.com
I have been using it in my new 502's. Guess I won't know if it works until we have a problem.
Dail
Tom 02-07-2003 01:45 PM
Salt away for the engine inside and WD40 on outside surfaces is what I've been told.
Steamin Rice 02-07-2003 03:56 PM
I've been flushing my motor with salt-away every time I use it, plus I coat the outside hardware with wd-40...
FloridianSon 02-07-2003 05:27 PM
I too just picked up some salt away kind of stuff from the store,if it works half as well as it says it does I 'll be happy:D
Ric232 02-08-2003 08:43 AM
The best stuff for the outside of the engine is CORROSION BLOCK. It's about $15 per can, but it works much better than WD-40.
Rocky Dell 02-08-2003 03:57 PM
Corrosion-X is what I use on the outside of the motors. It's about $15 a can, but if you buy it by the case it drops to about $11 a can.
Ric232 might be talking about the same stuff. They possibly have changed the name. I haven't bought any in about a year.
Anyway, you don't have to use it every time. It lasts a lot longer and doesn't have any alcohol in it to dry up any exposed rubber.
Rocky Dell 02-08-2003 04:00 PM
Here's the link for Corrosion X if anybody is interested.
http://www.corrosionx.com/
Macklin 02-08-2003 04:12 PM
Salt Away for the inside.
Does anybody know if West Marine, Boat US or Boaters World carries Corrosion-X?
Rocky Dell 02-08-2003 04:15 PM
I've never seen Corrosion X in those stores. Look at my link and it tells you where you can buy it. I ordered mine from a small distributor in Delaware and he shipped it to me.
Rocky Dell 02-08-2003 04:18 PM
This is the type of "Corrosion X" that I use on the marine motors.
http://www.corrosionx.com/marine.html
FloridianSon 02-08-2003 04:32 PM
I use the Mercury brand corrosion guard on my out drive and k'S and don't have to put it on to offen. I do know don't breath in when your down wind from this stuff:(
florida gator 02-08-2003 07:59 PM
I know the local west marine doesn't sell either corrosion x or corrosion block. They do sell the corrosion block grease though.
Rocky Dell 02-08-2003 10:05 PM
Here's where you can buy "Corrosion X"
http://www.corrosionx.com/DL.htm
