Like Tree0Likes
What should I use to fill the stress cracks I ground out on the bottom of the boat?
Old 02-06-2003, 10:22 PM
Pure Energy's Avatar
My Boats: 2001 Superboat Y2K
Thanks everyone for the help! It is too cold right now for any kind of apoxy, so I will continue to prep and look through all the info.
thanks all
Kendall
Pure Energy is offline
Old 02-06-2003, 11:33 PM
Charter Member #232
Audiofn's Avatar
My Boats: 1979 Formula 302, 99 Formula 353, 81 Donzi 18 2+3 with 454
Default Amine Blush
One easy way to solve this problem is to take a scrub pad (scotch brite works well) and put water on it and scrub the surface. If you do get any blush this will take it off and you will have no problems. This is of course assuming you use a epoxy of some quality. Again epoxy on polyester you are fine, polyester on epoxy you want to try and avoid, vinalester on epoxy is ussually ok but still not the best. That is how it has been explained to me anyhow.
Jon
Put your best foot forward!
Audiofn is offline
Old 02-07-2003, 07:53 AM
H2Xmark's Avatar
My Boats: 1997 Fountain 35 Lightning
Some great tips and ideas here, like you said it is to cold so you might as well read up on some of this stuff, i'm no pro by any means on this matter, and I try to read what I run across, good luck
H2Xmark is offline
Old 02-07-2003, 08:34 AM
MitchStellin's Avatar
My Boats: Zodiac RIB
The best way to stop this from happening again is to grind until the crack is gone. Then use strips of fiberglass to fill in the ditch you made. This would also apply to the voids in the lift strakes. You then need to grind, dand and fare the whole mess until it is smooth. We used a blue paint to sand the areas down and that helped us see the dips in the bottom. My bottom was like a road map. We worked on it for over a month and then put a new gel bottom on it. It was tons of grinding and sanding but it was done right. The guy who helped was head of production for Tiara. He knows his stuff and now I do since I was there with him.
MitchStellin is offline
Old 02-07-2003, 07:50 PM
H2Xmark's Avatar
Hey Mitch, did you strip the old gel or did you gel over the old stuff? what did you use for resin on the glass?
thanks
Mark
H2Xmark is offline
Magnum25
Fiberglass and Paint
1
10-21-2006 09:57 AM
klmken
14
07-24-2006 11:30 AM
ROADHOG
Sonic
2
06-04-2004 08:12 AM
RJ1340
3
12-08-2003 12:59 PM
rick32
Sunsation
13
10-08-2002 11:18 AM
