Attn Dyno Guru's...
Attn Dyno Guru's...
Hello "Dyno Gods"
I was wondering what size "auto headers" you would use for the H2O motors, to equate to Eickerts's cast alum headers ?
My question is what tube diameter is equal or close to a set of
KE's ? I called KE and they were not sure ,it seems the "brains" are at the Miami show.
I need to get as close to "real world" as I can.
Thanks guys
Thanks guys
most dyno headers are 2"- 2 1/4" tube diameter. big cu. means bigger tubes, most marine headers are 2 1/4 on the inner tube. The jetting and tuning items done on the dyno will be slightly affected by header size. If you are doing a race application, use your headers for max performance tunning. If you build a poker run, pleasure motor, tune it to max with good dyno headers, then back up to the rich side tune up. Your motors will live a lot longer.
