#6 and extension boxes
Does anyone have an opinion or experince with the ride of a 38' top gun with #6 drives and extension boxes installed??
1 Attachment(s)
Might want to get ahold of WickedWon, he has them on his
41' Saber with Staggered 1,100 hp. if I remeber correctly. The boat is at Saber right now. |
2
1 Attachment(s)
3
1 Attachment(s)
3
Cigar - Typhoon Performance Marine in NJ rigged a 38 Top Gun TS with #6s and big power, within the last 2 seasons. They can give you some information. Ask for Chuck B.
Forget it!
All the 38 cigs with #6s struggle with too much stern weight. The only one that excepted it OK was Mr Proctors boat and that was because he had staggered engines. Find a pair of #5s with boxes, you will be better off.
TRES
when you say struggle do you mean getting on plane, porposing.or ?????
BlondeCigChick has a 1994 TopGun with 900sc's, #6 drives and extention boxes. Jeffrey put it together.
p.c.
who's jeffery???????
Jeffrey, as in the moderator; as in the guy who started OSO. El membero numero uno.
I have to say that TRES is correct in stating that the boat has too much stern weight. When I re-rigged Ruckus (1994 Top Gun - full cabin - 900 Pfaffs - #6 drives) with the Stellings stand off boxes and #6 drives - it was based on my experience on another Top Gun that was similarily rigged. Some of you may remember a Top GUn called "Kangaroo Rat." Kangaroo Rat was a big power, bad ass Top Gun with #6's and boxes. The difference was that it also had 500 pounds of electronic equipment down below up front in the v-berth (three tv screens, etc.). In other words - it was a heavy a** boat with alot of forward weight which was offset by the boxes. Ruckus - not having that same weight - is too stern heavy 80% of the time. I have repeatedly told Anna (current owner aka Blonde Cig Chick) that she should re-rig it without the boxes, however, she loves the way the drives look hanging five feet off the transom. The boat porpoises more than normal under 70mph. You definately need those long tabs in the water to compensate for the weight imbalance. Problem is - tabs downs equals drag which equals slower speeds. The one very good thing is that Ruckus will run like a bat out of hell at 80+. All that weight in the stern actually lends stability at higher speeds. Problem is that no one runs around at 80+ 90% of the time. Bottom line? Don't do it unless there is a specific reason to do it.
Jeffrey |
So, if I understand this correctly, the #6 drive on the To Gun is fine, just don`t use the extension boxes?
Or is the Six drive just too heavy for the boat and as Tres mentioned, 3 or 5 would be a better choice??? If money was no object, what would be the ideal set up for a full cabin heavy, older, nonstep Top Gun? Kurt. |
| All times are GMT -5. The time now is 08:12 AM. |
