Trailer Tires?
Old 02-20-2003, 04:31 PM
97BossHammer's Avatar
Default Trailer Tires?
I need to replace the tires on my trailer. Question is do I need to get specific with them or just get some ordinary replacements. I plan to go with a decent brand but I've been told by a lot of people to just put regular ole tires on it and let it rip. My wheels are 15inch and I'd like something a bit wider too.
97BossHammer is offline
Old 02-20-2003, 04:36 PM
formula31's Avatar
Get the Goodyear Marathons from Tirerack.com. There are plenty of good reasons not to use regular tires.
formula31 is offline
Old 02-20-2003, 04:55 PM
Playn's Avatar
get the proper load rating
Playn is offline
Old 02-20-2003, 05:29 PM
I use good year marathons too on the trailers I sell . most Car tires will dry rot on trailers. What ever brand , make sure they are "trailer" tires . Usualy marked "ST" for " special trailer " tire . ANd get the right load range "C, D, or E" depending on your boat weight .
boot is offline
Old 02-20-2003, 05:51 PM
My Extreme trailer came with 14" rims with "C" rated tires that aren't the right load range for my boat. I blew 5 trailer tires last year and don't want to go through that again this summer. Does anyone know of a D rated tire that will fit on a 14" rim? I'm even having trouble finding a D rated 15" tire with a 27" diameter so that I can fit it under my fenders.
Robbie Racer is offline
Old 02-20-2003, 05:56 PM
sauron
Don't help pay for the blimp, get Michelins. I pull all over the country and have never had a problem with them. Blown out many Goodyears and other brands.
Old 02-20-2003, 06:28 PM
liquid asset's Avatar
Marathons suck you can have those peices of chit. I've blown several but I do tow at 80 like a dumbazz I use Carlisles from discount tire never had trouble with these. I had so much trouble with my goodyears, bubles on the sides, they gave me new carlisles. they are about 59 bucks a peice. Always use special Trailer tires no matter what anyone tells you
liquid asset is offline
Old 02-20-2003, 07:18 PM
H2Xmark's Avatar
what matters most is get trailer tires because they have more plys and will not flat spot as easy as car tires, and get the proper load range, other than that the brand is your choice, you will hear good or bad about all tires, put it this way a chunk of metal in the road does not care what brand tire you have
H2Xmark is offline
Old 02-20-2003, 07:52 PM
mama tryed's Avatar
we have 225/75R15 D-rated Marathons for $71.50
I dont have any Specs on the Tire, here at home, but you can call me and I'll look them up for ya!!
1-800-231-2295 ext129
mama tryed is offline
Old 02-20-2003, 07:57 PM
mama tryed's Avatar
I dont have any Specs on the Tire, here at home, but you can call me at work, and I'll look them up for ya!!
Quick Reply: Trailer Tires?
