How do you reclaim antifreeze at first start up?
I used the biodegradable antifreeze but still do not want to dump it in my yard when I start up for the first time this spring. Is there a way to reclaim it during start up? Most of my property's runoff leads to a stream that runs into the local resevoir.
For my through hulls I zip tie dryer hose over the pipes into a bucket and put a bucket under the bypasses.
Don't Let It Hit The Grass, My Buddy Did And He Still Can't Get Grass The Grow.... I Start Mine In The Driveway And Let The Sun Evaporate It Off The Cement.... Not A Good Answer But It Works For Me........
I'll probably take mine to moms house and start it in her driveway!:)
It might be biodegradable but it degrades grass also. Neu-rich is right.
This may be a little sloppy, but you can alwys drain everything into the bilge and put a bucket under thedrain hole on the transom, just fill a small pail a few times, then you can use it next year. Just be sure to test the anitfreeze before you use it again.
Pull it out of the driveway and start it in the street.
Go to a local car wash that has a hose or an appartment complex.... friends house? When I lived in NY we just ran it into the street from the boat and the motor home water system...
But Chris you live in Orlando now you know we dont have to do stuff like that:D
I know... and its GREAT!!!!! :D
I had the bioderadable stuff and let it go down the driveway. I ended up killing the grass down the drive, across the front of my yard and two neihbors yards. Man was I embarrassed. It won't grow grass there anymore but at least I don't have to edge. The best and safest way is to capture it in a bucket like stated above. This will cause the least amount of damage and keep you out of jail from the DNR. Hey, it was -6 here this morning so don't be too quick to drain it:D
For you guys with the dead yards, just dog out 3-4" of the contaminated soil, water down the area VERY good and then replace with shredded topsoil(pack down the soil, then put about 1/2-1" of loose stuff on top, this will prevent any sinking/compacting of the soil), put down grass seed, starter fertilizer and straw. Keep the new soil DAMP for about 4-6 weeks.....wha-la....yard will lood good again.
Just try to use a grass seed that is somewhat similiar to the existing lawn. i.e.......don't use Kentucky 31 in a Bluegrass lawn. Later, ALLAN |
Hmm, I figured you could pour it into the river. I just went to the PEAK site and looked at the MSDS. Guess what: you can't pour it in the river. You CAN pour it down the drain, though.
Apparently while it is okay to drink the stuff, it isn't real compatible with GILLS. Long term Toxicity levels for a minnow are 10,000mg/Liter (that's the low number - the range is up to 56,000). That's less than an ounce. This means that you can only dump 176 gallons of the stuff in a swimming pool (16,000gallons) and not kill the minnows in it. I'd sure hate like heck to dump 7 gallons of it into a billion gallon reservior that changes out the water every half hour... |
I use the same method as Allan 4
| All times are GMT -5. The time now is 09:14 AM. |
