Engine compartment paint?
I just recently pulled the stock motor out of my Velocity to prepare the engine compartment for a new motor hydraulic steering and 280 K planes. I have also removed the flooring on either side of the motor and the carpet from the sides of the hull. I want to smooth everything up and paint the area before I start the assembly process, so the question is what kind of paint does everyone use in the engine compartment?:)
I used Interlux Bilgekote in white. It seems to work well and gives a nice semi gloss finish. How it holds up over time we will see but this is what it's made for.
Pretty easy no mixing no harsh or dangerous fumes. Pop th lid and paint. I got mine from www.defender.com |
Do you use a brush or is it in a spray can?
brush is easier in bilge
AWL-GRIP IS GREAT, IT CAN BE SPRAYED OR BRUSHED ON.
AND IS ALMOST IMPOSSIBLE TO STAIN. IT IS ALSO VERY VERY DURABLE. |
Anyone done something other than white?
Brushing is the prefered method for the typical do it yourselfer OSO member.
Bilgekote is also a great product. I have seen the results and it looks good. |
Mark, call me I will tell what to use Kenny
I'M NOT SURE WHAT COLORS ARE AVAILABLE.
WHITE IS WHAT OUTERLIMITS USES. |
1 Attachment(s)
white will show oil leaks easily. awlgrip over gel coat is what i used. looks wet.
1 Attachment(s)
awl grip is the answer, and I am sure it comes in colors. I did my Active Thunder in yellow.
i used EASYPOXY and it worked well. Its a one part and i sprayed iton. Nice tough finish. White does show spills though.
Interlux Bilgekote-Gray
Went on VERY easy. Tough as Nails and looks great. I Was told it is a semi-gloss but damn sure looks like Gloss to me...I bought mine at West Marine....I would use it again in a heartbeat. Bad-Habit |
Bilgekote is only available in grey and white. It brushes on and lays down nice.
Imron 333 series is brushable and you can get it in many different colors. Activated and accelerated it runs about 74.00 a gal.
| All times are GMT -5. The time now is 04:44 PM. |
