-   -   towing issue (https://www.offshoreonly.com/forums/general-boating-discussion/47068-towing-issue.html)
DJW 04-05-2003 06:06 PM
towing issue
I have a 98 Tahoe that I tow a 28 Baja Sportfish with. It tows the boat just fine, but I am exceeding the GVWR. I bought a 1989 2500 thinking this would be better. It is not. Can anyone explain why? The truck doesn,t have enough power . Is the 98 Vortech engine the difference. Could I install a Vortech 5.7 in the 89 pickup without to many problems? Any help is appreciated.
Thanks, Dan
gmhdfan 04-05-2003 08:01 PM
You have two problems. The 89 motor and the extra weight of the 2500. If its a 2 wheel drive you might get away with changing the gear ratio. You can put a vortech motor in it but you will have to change the ECM. And you would be better off using a "stand alone one" like the street rod people use because you don't have an electronic shift transmission or OBD-2 on the 89. A friend of mine has the same truck. I put a set of vortech heads and 4 barrel intake (all bought new from GM) and it wasn't to much money. He's happy with the truck now. Just something to think about. The vortech heads are a cheap HP bolt on thing. I'm sure your happy with the better brakes now. Good Luck.:)
DJW 04-06-2003 12:27 AM
Thanks for the info, it is a 4wd, do you get rid of the throttle body in lue of the 4 barrel? Will the truck tow better with some bolt on upgrades?
gmhdfan 04-06-2003 08:49 AM
Yes, we put a Holley on it with a fuel regulator. See what gears are in it. His still had a TH400 tranny so he didn't want anymore gear. I put some low gears in a late model 4X4 (OD tranny) and only changed the RPM a couple 100 at highway speeds. But had a ton of more bottom end power. Good Luck.
