1998 500 bulldogs ?
Old 04-04-2003, 01:28 PM
LapseofReason's Avatar
Default 1998 500 bulldogs ?
Are they just the 500 hp or is there a difference? what went wrong with them? I know the hp carb motor had some problems for a while but that all was fixed about the time the EFI hp came out. I know some had valve spring problems, and heard about cam/dist. gear problems. What else and what did they need to be trust worthy with the Whipple set up.
LapseofReason is offline
Old 04-04-2003, 01:38 PM
it's a great motor. basically bullet proof. it has all the good stuff in it. they don't makem because people did not want to pay the price.
Treadwell
Treadwellmotorsports is offline
Old 04-04-2003, 01:42 PM
So it's not just the hp carb ?
Old 04-04-2003, 01:49 PM
Received 1,814 Likes on 903 Posts
Nope, not the same. The 500 Bulldogs are 540 cubic inches. They do still have 500hp.
Griff is offline
Old 04-04-2003, 01:50 PM
OldSchool's Avatar
I think they are 540 CI
OldSchool is offline
Old 04-04-2003, 01:54 PM
I just did some other looking it apears that a 500 bull dog is the 540 bull dog. 540ci 500hp people just use one of those #'s and put bull dog behind it. I knew what the 540 was just never heard about the 500 before. I guess it depends on who you are for what # you use, I like 540.
Old 04-04-2003, 01:55 PM
Now I need Dustin to chime in with the dyno #'s for one with the Whipple's on it.
Old 04-04-2003, 02:38 PM
Very good, expensive motor.
540 cid, tall deck, 4.375 stroke, all the good internals. Block, crank, and heads are the basis for the 900SC motor.
I think it originally came out as a 575 hp NA version years ago. Lots of potential in those motors.
Gary
Gary Anderson is offline
Old 04-04-2003, 08:06 PM
Bulldog's Avatar
The 540 was originally a 575 MCM. This was a 540 with a 1050 dominator carb. The 540 bulldog was almost the same engine with a smaller (850?) carb. It was rated at 500 HP, but at a lower RPM range which means it had more torque. The later engines were internally balanced. I have an article with specs and will look for it- Cool name for an engine.
Bulldog aka Ronnie
Bulldog is offline
Old 04-04-2003, 08:36 PM
thisistank's Avatar
Received 2,962 Likes on 981 Posts
They are the same as the "bow tie blocks" right??
I know a guy that might want to sell some that have been boxed up for over 5 years.
Tank
thisistank is offline
Quick Reply: 1998 500 bulldogs ?
