-   -   Another Dumbass Rookie Question (https://www.offshoreonly.com/forums/general-boating-discussion/47617-another-dumbass-rookie-question.html)
bouyhunter 04-15-2003 04:35 AM
"steps" are there to introduce more air under the hull and give more lift to the hull causing less drag (friction with the water, shorter running surface...). I'm by far no expert on this, but from reports by reputable sources, some manufacturers seem to have it dialed in better than others. - as far as the placement and size of the step. Most complaints tend to be handling in turns with poorly spaced or overly aggressive steps. It is also said that steps are only effective on a 30'+ boat.
Hope that explains a little. Just my limited knowledge.
cig1988 04-15-2003 05:58 AM
27' activator has steps. Ran F-1 and kicked ass.
packinair 04-15-2003 08:34 AM
Originally posted by puder
see if you can find a pic of the bottom of a batbat they have like 7 steps in them..
Now what in the hell is a batbat???
wwwTOPDJcom 04-15-2003 10:03 AM
thats when you smash 2 Batboats together and they no longer float :D :D they are usally found on the ocean floor
BLee 04-15-2003 10:33 AM
A stepped hull Cigarette with lets just say 500hp's, will smoke a conventional hull with the same power.
More bang for the buck
ChrisK 04-15-2003 12:00 PM
Re: non stepped hull
this is a non-stepped v-hull
HEHE Hey thats ME! :D
puder 04-15-2003 01:03 PM
yeah i figured the pic showed offthe bottom well
