Looking for a 1.36 gear set anyone?
I'm looking for a set of 1.36 (15/17) teeth lower gear set for XR or XZ Bravo 1 anyone have a set???
[email protected] |
Are you talking about the upper gear set? I thought that all of the Bravo's had the same gear ratio in the lower unit. I have a 1.36 upper, but it is not XZ or XR.
Can someone answer this question for us? |
I have two sets from my IMCO Extreme SC Drives. They were on the large prop shaft lower if it matters I'm not sure. Only about 40 Hours on them.
No I'm looking for a lower set what happened is I have a Imco drive and I broke the upper gear set old style that were 1.36 and had the new style XR gears pout in that are 1.50 thats why I'm looking for a lower set to get me back to 1.36 I thought about re popping but I'm trying to think ahead if I ever want to make more power I would have to re gear any way. With the 1.50 gear I'm on the rev limiter jest over half throttle at 5600rpm with a Bravo 1 30p at 95mph.
Put a 34 pitch on it. You are going to break this gear set any way, this way you get some time on these then go with the 1:36, I think IMCO has a 1:2something gear also. I gather it must be a cat.
The name gives it away (Mn Howard Cat) Minnesota Howard Cat
| All times are GMT -5. The time now is 04:48 PM. |
