Does anyone have a "Ready Welder" ?
I might buy one . I need a spool gun for a little aluminum work and this sounds good for around $529 ....... Any body have one ? How are they ? It's cool . It is portable and can run off 2 car batteries if needed .
http://www.readywelder.com/
I sell them and have them in the showroom for $499
If they didnt work we wouldnt be selling them. Most of our customers run them off there gas drives but I have seen it demonstrated with 2 12volt car batteries (steel).If doing aluminum there is a modification that you will need to make to the gun. You need to make a jumper liner between the drive roll and the tip. For some reason they dont use one. If doing steel it is fine but aluminum will bind.
Let me know if you have any other questions.
If you want to demo it before you buy it come on over.
AGL Welding Supply
Clifton NJ
AGL Welding Supply
Clifton NJ
Here's another one that is suposed to be better for $389 !
http://www.mtgilliland.com/cgi-sz/we...38103092382.22
Sorry Tantrum, I didn't see your post . What do you think of this second one ? What's the difference between ready weld ,and ready weld 2 ? I see the second one has ac adapter.......... Thanks for you input . JOE
The one I have is the Ready Welder II
Klaw; most of these things dont work. The Ready Welder does BUT you have to be realistic. A lot of times the sales liturature will reflect unrealistic conditions that wouldnt normally be met in a shop invironment.
Boot; Im at my desk until 6 ; 973.478.5001x616 Chris
speel chekk this fokker!
i've done small stuff with olod car batteries and jumper cables. Its messy and a major jerry rig, but in a pinch it does works.
Pardon me, while I whip this out!
