Big white MTI
Old 06-26-2004, 02:55 PM
Default Big white MTI
Friend of a friend just bought a 40+' MTI with twin turbines and shaft drives, just saw it sitting on the side of the raod down the street..wow...Matt
fobes is offline
Old 06-26-2004, 03:04 PM
Rob
Strip Poker 388's Avatar
Default Re: Big white MTI
Take a picture .
Strip Poker 388 is offline
Old 06-26-2004, 05:52 PM
What is the operating costs of turbines? I was always under the impression that turbines are generally more reliable than piston engines and that the major concern was cracking fan blades. Someone educate me.
Dblvanos is offline
Old 06-26-2004, 09:56 PM
Will try to get some pics tomorrow, boat is 44' and has a four man enclosed canopy w/ a/c and escape hatch into the tunnel, turbines are made by MTT, has the Buzzi straight surface drives with a rudder for steering, boat is a 2004 and is all white, heard that it will run in the 170 mph range. I don't know what the operating costs are but the turbines can run on a variety of different fuels but if the motors ever break I can't imagine you can just pick up the phone and get any old shop to send someone down. Boat is very nice looking...Matt
fobes is offline
Old 06-27-2004, 06:32 AM
GLH
GLH's Avatar
There is a guy here on the lake with a Skater with two turbines.
The cost to run it must be high because he almost set three sail boats on fire last time he was parking at the marina...
The problem is those turbine burn almost as much gas at idle as they do WOT, so think how your rig would drink if it was WOT whenever the key was on. However if you can afford to turn it it should run 2000-3000 hours between $70-80k overhauls. Ho yes, we haven't talked about putting the power to the water yet, wierd trannys set ups and $10k props...
GLH is offline
Old 06-29-2004, 05:17 PM
SPITFIRE's Avatar
any pics yet????I'll be Boston this weekend and have to check her out!!!
SPITFIRE is offline
Old 06-29-2004, 06:56 PM
Downtown42's Avatar
that will keep 'em from turning left in front of you
Downtown42 is offline
thisistank
10-05-2007 12:30 PM
Top Banana
08-01-2006 06:43 PM
Top Banana
General Racing Discussion
3
08-01-2006 09:44 AM
Anarchy Powerboats
11-26-2005 02:00 AM
TeamTaboo
04-26-2004 07:24 AM
Quick Reply: Big white MTI
