Well, I'm done for a while. Where can I get new fuel tanks and what kind? >
Old 06-16-2003, 10:58 PM
Bulldog's Avatar
My 4 saddle tanks were foamed into bays along side of the engines (full stagger). The bottom halves of the tanks are in foam, the upper halves exposed. It appears that the tanks separated somewhat from the foam, and then water stayed trapped in the crevices (crevice corrosion??).
I used a tree pruning blade to saw through the foam. I have to pull the engines this weekend to lift the tanks out, and still have to remove foam from the starboard rear tank. I will try using a pressure washer to slice through the foam, and will post the results.
I just had 4- 60 gallon saddle tanks fabricated locally and cost $400 each. Constructed from .125 thick 5052h32 aluminum.
I am going to coat the bottom halves with Gluvit waterproofing epoxy before foaming them back in. Gluvit dries somewhat flexible and should give me a reasonable degree of corrosion protection. I am also thinking of using a 2 part pourable catalyzed rubber sealer to seal the top of the foam.
If anyone knows a better way to do this, I would like to know!!!!!
Bulldog aka Ronnie
Bulldog is offline
Old 06-17-2003, 09:18 AM
Tantrum's Avatar
1st stage complete
HotBoat, Pure Energy, HotBoat, myself and HotBoat worked on pulling the tank last night.
HotBoat is a mad man, you would have thought this boat cheated on him with his best friend on his wedding night in a past life or something. The boy had pure fire in his eye's and the fuel tank was on the recieving end. No doubt this guy aint takin anymore sh!t from a piece of floating fibergalss
We finally got it out at about 1:30am.
At about 8:30pm I had my doubts, by 10:00pm I knew it was going to be a long night, and by midnight I was wondering how I was going to talk HotBoat out of taking it out through the bottom of the boat........I think Pure Energy might have even gone with that option .
Ill post some pics later in the day.
Tantrum is offline
Old 06-17-2003, 09:24 AM
28SS's Avatar
taking a foamed in tank out is one of the worst projects to do on a boat ! Never thought of taking it out thru bottom
28SS is offline
Old 06-17-2003, 11:41 AM
Team Dysfunctional
Hot Boat's Avatar
Dude That sucked!!!!!!!!!!!! But I refused to give up. I didn't get home till 3:15 I ended up taking the day off to recover. I couldn't be much good today with all the cuts in my hands.
Kendall sorry for the big hole in the hull Don't worry I can fix it .....I can fix anything ..... Just give me some duct tape
Hot Boat is offline
Old 06-17-2003, 03:15 PM
Pure Energy's Avatar
Come on Paul, it wasn't that bad!!!
Pure Energy is offline
Old 06-17-2003, 03:49 PM
Team Dysfunctional
Hot Boat's Avatar
Just think. You are only half way done
Hot Boat is offline
Old 06-17-2003, 04:12 PM
You are coming back.....right?
bigboat28
Pantera
4
08-04-2008 11:35 AM
ActiveFun
Powerplay
7
05-03-2006 10:24 PM
cougarman
Apache
13
03-22-2005 07:57 PM
SLINGSHOT
02-10-2005 07:32 AM
TomR
4
04-25-2002 08:50 PM
Quick Reply: Well, I'm done for a while. Where can I get new fuel tanks and what kind?
