-   -   Dyno, about your oil leak (https://www.offshoreonly.com/forums/general-boating-discussion/52594-dyno-about-your-oil-leak.html)
Crazyhorse 06-17-2003 07:45 PM
If you want to do another R&R I'm sure we can get to the bottom of that oil leak. Let me know.
MACDAD260 06-17-2003 08:52 PM
Don, Did you pick up the the dye I left at MD? Before you pour it in I would mix it with at least a half quart of motor oil and then pour it in. Since there is such a small amount of it, by mixing it with some more oil you will be sure it gets down in the pan right away. Otherwise, it may take a while before it gets mixed with the oil that is already there. If you have enough room to shine the black light in the area that you suspect the leak to be coming from it should show up as greenish-yellow streaks as soon as the oil gets warmed up good. I also have a small black light on a flexible shaft that I can loan you. It may allow you to get into a smaller area. Let me know how it goes. Good luck.
dyno 06-18-2003 07:59 AM
I'm planning on getting the boat on thursday night and getting it where I can work on it, not in the rack at the marina. I might have Friday off should know later on today then I should be able to make some headway. Doug I did get the dye thanks alot! I'll send you a check. Dave I know youe A$$ hole deep in drive issues but any help I can get will be great!
fred 06-18-2003 08:13 AM
Dyno, I'll be at the marina early Sat. morning....let me know if there is anything I can help you with....cell# 517-819-5113...Fred
dyno 06-18-2003 02:31 PM
Thanks Fred!
