-   -   Smoked bearing for dinner / help from Chicago (https://www.offshoreonly.com/forums/general-boating-discussion/53393-smoked-bearing-dinner-help-chicago.html)
RUSSSR1 06-30-2003 12:31 AM
On the way home from the north woods last night my trailer tried to find out how far it could chuck a wheel. Thank God it did not hit anybody. All that is left is a cooked spindle, found the wheel though. Drum and hub cracked to nothing. The bearings were just greased and not a half hour before they were cool as could be at a gas stop. Well the boat is stranded about 50 miles north of Milwaukee safe at a boat dealer. The guy at the dealer said he has no idea how long it will take to find the parts. This does not work for me or the people that are planning to see some fireworks from the perfect view of Lake Michigan. So I need parts ASAP, spindle, drum/hub, bearings, linings. Who in Chicago / Milwaukee stocks trailer parts? I need this stuff now so I can go rescue my boat.
candyman35 06-30-2003 01:56 AM
Russ,
Brett trailer supply stocks a lot of parts. They are in Crestwood IL. It's about 3 miles south of the 294 & Cicero exit. If you need me to pick anything up call me at 708-218-1566. After 10:00 am.
Great weekend, need sleep.:D
Dan
RUSSSR1 06-30-2003 07:57 AM
Thanks Dan
I will give them a call.
obnoxus 06-30-2003 08:55 AM
Yep,,, Brett is where I get everything,, and they have it all in stock,, all the way to a new axle if you needed it.
obnoxus 06-30-2003 08:56 AM
P.S. I have a complete drum set up for 1 side,,, the other side went bad and I converted to disk,,, might not be a bad time for you to do the same.... but like I said,,, I have a complete drum setup here if you need it.
CAll me 708 218 6253
