-   -   slow getting on plane? (https://www.offshoreonly.com/forums/general-boating-discussion/53718-slow-getting-plane.html)
Here's Johnny 07-04-2003 05:30 PM
Usually when I go out I travel light...today I had about 5 people on board with lots of food and drink...all totaling about 1000 lbs. When ever I would get on it the boat couldn't seem to get on plane...no I don't have tabs but I am running a 454 with 330 hp...does this sound possible...she would sit at about 2000 rpm for 2 minutes then ever so slowly come on plane and top out a few mph slower then my normal top end...does the extra weight make that big of a difference?
Raypanic 07-04-2003 06:19 PM
Put as much weight forward as you can.
Von Bongo 07-04-2003 07:28 PM
Yep, move the weight forward until on plane.
Jassman 07-04-2003 09:49 PM
How is it when just a few people are on board, is it realatively slow to get on plane, maybe your X dim. is set to high and geared towards top end. Try a spacer, a 1/2"-1" really makes a difference on getting on plane, we have a few excellent used ones for sale that you can try, if not return them for a full refund, let me know if I can help, Jeff.
frequentflyer 07-05-2003 08:15 AM
Dude. Sounds like you need another 454 :D
Honestly, It can happen to most boats. Move the weight forward if you don't have tabs and see if that helps. If it does, get tabs...
Here's Johnny 07-05-2003 09:02 AM
Thanks guys, I am going out tomorrow for a solo run...i will keep ya posted...
RM2 07-05-2003 02:35 PM
Also, if your engine rev's a little on the low side of the recommended RPM at WOT when the boat is empty, you may try dropping a couple inches off the pitch on another prop to get better torque loaded down.
Here's Johnny 07-06-2003 04:00 PM
Went out today with 4 people and no baggage...what a difference...right up on plane...I should probably spring for some tabs but I am feeling that this is my last season with this boat. Thanx again guys!!
stevebaretta 07-06-2003 04:08 PM
added tabs.....big differece also if i know i'm going to be hauling
a group of people, i put on my High five prop
