-   -   Problem with HP575 (https://www.offshoreonly.com/forums/general-boating-discussion/54356-problem-hp575.html)
FormulaFan 07-14-2003 07:08 AM
Problem with HP575
Last weekend, while running in a poker run one of my 575's started backfiring and missing above 4500 rpm. The next day it ran perfect. Anyone have any experience or suggestions regarding this problem? Thanks....
Von Bongo 07-14-2003 07:50 AM
Obstruction in the fuel line?
I have 30 hours on mine and no proplems like that.
Rippem 07-14-2003 09:33 AM
Wet distributor? :confused: It would dry out overnight in the heat of the engine room.
bobby daniels 07-14-2003 10:23 AM
wipe out dist cap with acohlol and try a set of plugs ,crank motor set if it has blow by out the valve cover oil filler hole ((Pray Not))
Then leak down test motor ,then pm me if you haven't found it
good luck
FormulaFan 07-14-2003 04:24 PM
TTT
CESSNA 07-14-2003 04:33 PM
Guess your TTT because you've tried the stuff above ,"NOT",- try it then ask more no one can answer any closer unless they are there WTF
FormulaFan 07-15-2003 08:03 AM
Cessna, I wast just looking for more suggestions. Thanks to Von Bongo, Rippem, and Bobby for your help. I will try your suggestions this weekend and let you know how it goes!
OldSchool 07-15-2003 08:15 AM
You forgot to thank CESSNA for all of his help!!:rolleyes: :rolleyes:
FormulaFan 07-15-2003 11:07 AM
Hey Craig, I think CESSNA is having a bad day!
CESSNA 07-15-2003 11:14 AM
Yea ,its my time of the month ! I just don't want those guys to get tired of postingwhen it looks like we do try what they say those guys and others help alot vonbongo's helped me before
I'm no help I enjoy reading this stuff to help my boating .
Later
cardoctor 07-15-2003 12:51 PM
maybe spark plug wire arcing against block or bracket
cardoctor
Joe 10-01-2003 10:58 AM
Hey Steve...
I had the same problem a couple yrs. ago while on a Poker Run in Florida. It was a fuel pump just starting to go bad. It was on again and off again and drove me nuts -- EVERYONE told me how bad it sounded. We diagnosed it and I had a new pump on in an hour. They're pretty easy to replace. Not sure if this is it, but if everything else fails, here's something else to try. Hope it helps!
Quiet Storm 10-01-2003 02:17 PM
scarabfan
Your original post was from a few months ago. Did anything else happen to your motor?
FormulaFan 10-01-2003 03:09 PM
No, it has not had the same problem since. It was an extremely hot day, and I was running it hard in a Poker Run. The dealer said the heat probably caused a vapor lock in the fuel line. The motors have been running perfect, I have 125 hours on them. They are big-time gas guzzlers though! I would get 525's if I had to do it over! Thanks...
Quiet Storm 10-02-2003 06:55 AM
From what I understand the 525's work better in the warm climates. We don't have that problem often here.
As a precaution you probably should change your head gaskets. I just lost one on my starboard side. The owner of the boat before me lost a fuel pump and I think that may have damaged them.
Yes they do like gas and if they don't get enough, they get mad and break something.
Dano 10-02-2003 09:42 AM
There was a fuel rail recall on those motors...if they haven't been changed out that could be a contributing factor. Resonance in the fuel lines themselves could cause disruption of flow to the injectors.
I run the 575's and changed out gear ratio's to run a more efficient prop and fuel economy increased dramatically (now I stop at every OTHER gas station...)
