Verizon/Phone help?
Verizon/Phone help?
Ok My damn line house phone is all static when I pick it up. But I can get incoming phone calls no problem. I went outside to that box on my wall and I pluged in a phone to the test port and I still hear nothing but static. Does it sound like it's in the house or their line?
If you unplug the wiring from the house and plug the phone directly into the outside phone jack and you hear static it is the phone companies problem.
Has it been raining a lot where you live???
OSO Content Provider
Commercial Member
You either have a crossed line or a high resistance open.
Trouble is definately in the phone company's cable if you plugged into the interface on the side of the house and the trouble still exists...
Hopefully there will not be a strike and you get a quality technician to make the repair.......
I don't have dsl and yes it has been raining here off and on. Yes I did take a phone and plug it in at the orange test port on the box outside and yes it still has static. Last week a repair guy from Verizon came out and wanted to enter my house at $90 + just to start and I asked him did you even check the pole in my yard? He tried telling me it was in the house and I said NO I'm almost sure it's your problem on your line. I'll call Verizon back again today thanks guys.
They will ALWAYS tell you that. Get you to pay then fix their line outside. They are responsible for up to the house. You are responsible for inside. You do have to either disconnect all your phones from the system or you have to remove the wires from the outside (the prefered way to test) then plug in your phone. If you have static with the unside lines removed you are all set and call them up. You can also go to Radio Shack and buy this little device that they have for testing crossed lines. My guess is some place you have a crossed line.
If you have undergound phone lines, all I can say is good luck. I just bought a house in Manahawkin a month ago, and everything is underground. Out of the 5 pairs coming to my house, 4 were bad (Puls the coax for my cable TV and modem.) Not a problem for some, but I work from home, so I need 3 phone lines + the cable modem.
Took 2 weeks for them to get a contrator out with a horizontal boring machine to shoot conduit under the street to the nearest pod. Then another two days for a Verizon tech to come out and terminate the new cable, which was supposed to be done the same day as the new run. On top of that, there were no free pairs in the pod, so another two days for a tech to come out and clear paths to the pod. All told, almost a month to get my 3 lines all working clearly. Can you hear me now?
Commercial Member
Capo71,
With all phones disconnected at the jack and the plug undone at the interface where the feed comes in, take a meter to measure resistance on your lines going into the house. First check for a short circuit by going across the pair. Then put one lead to ground and one lead to one side of your house wiring. Check both wires this way going into the house. If everything is good, then connect one phone at a time to make sure the phones are ok. Like I said, if you hear noise at the Interface the trouble will be outside. But that doesn't mean that is the only trouble. If a tech is also showing trouble in the house, unless you have the wiring maintenance plan, they will bill you if they come in.
Just have him prove to you there is a clean line coming to the house first before authorizing them to come in.
Also, you have other options with inside wiring, you can make the repair yourself or have another person such as an electrician repair it for you.
Rainmn, It sounds to me that you may have had a sprinkler system put in, or your neighbor did. These guys will usually cut the feeds to the house and half fast piece it together (sometimes) . All it takes is a small cut and then after it rains things start to heat up and breakdown the insulation on the wires.
The contractors do require 10 business days notice before coming out to replace the line.
This is because they need time for all the paper work to flow through the process plus they need to call for a Markout of all the utilities which they alone require at least 3 days notice. State law: "Call Before You Dig"
Sometimes I get lucky and a house is only 25 or 30 feet from the Pedestal with no obstructions. I will hand dig a new wire right then and there. It really isn't that big of a deal to do. I'm just slicing the ground and sliding the new wire in. It's not like it has to be 3 ft down or anything.....
Good Luck guys!
Good Luck guys!
