-   -   Wellcraft Scarab KV - how much power (https://www.offshoreonly.com/forums/general-boating-discussion/58140-wellcraft-scarab-kv-how-much-power.html)
Toffen 08-30-2003 01:04 PM
Hi!
How much power do you need to push a 38 Wellcraft Scarab KV to 80 mph + gps? 2 x 650 HP.....?
I know its a old design, but nice to look at. A classic. And reasonable priced in Europe.
Cheeers, Toffen G
Back4More 08-30-2003 01:48 PM
more like 750hp a side
Madcow 08-30-2003 10:51 PM
Tizbad had one with 800s that went 83. Good luck.
GLH 09-01-2003 05:57 AM
1 Attachment(s)
I just went for a 150 miles boat trip to Ottawa with a friend that has this 1986 38 Scarab KV.
Former Miami Vice Edition repainted.
He hits 67 MPH with a 425HP TRS set up running 21 pitched 3 blades. He has about 450 Hours on it.
Hope this helps.
KAAMA 09-01-2003 08:29 AM
A friend of mine has a 1980 Wellcraft KAAMA SE with a pair SUPERCHARGED 509" engines that make about 730hp each and if his boat donesn't run 80mph it is/runs very close to 80mph. I have run along side of him in my 32' Active Thunder. His boat is made out of Kevlar and has #2 SSM and does NOT have a notch in the transom. The 509's he has have flat tappet hyd cams, bowl/pocket ported GM rectangle port heads, Holley dual 750 carbs worked over by Nickerson, Superchiller innercoolers and aftermarket GIL exhaust manifolds with dry pipes.
I think at least a pair of tall deck 540 cubic inch engines would be good engines to start with and supercharge those. I don't know what kind of budget you're on, but they're not really that much more expensive and I think you'll be better off in the long run. I love the old 377 Wellcraft/Larry Smith flat decks!----Today, they still have the look and profile of a true offshore powerboat! Have fun! :)
TxHawk 09-01-2003 10:54 AM
Im am building a 82 40' excalibur currently. Very similar hull. We are using ITS extension boxes and XR drives. Our horsepower should be 700ish per side. We are expecting 75-80 out of it. The biggest gain will be losing the TRS drives and transmissions. Good Luck.
scarab kv 04-13-2013 08:17 AM
Hope this helps.
GLH, any idea where this boat is today?
MrSneakAttack 04-13-2013 10:19 AM
it depends on what drives are on the boat
